Trying to determine if the wheels from my 3-series will fit the S.
Specs:
Front: 19x8.5 +30 - 235/35/19
Rear: 19x9.5 +30 - 265/30/19
I would change sidewalls to 45, but mainly concerned with the offset. Looks like there is enough room, but wondering if anyone has any experience w/ +30 offset wheels.
Update 1: Called Tirerack and they recommend this:
* Front: 245/45/19
* Rear: 275/40/19
They thought 265 would look weird in comparison, not sure why/how. I also notice that there are no 265 wide tires available that MATCH the 245/45/19s...plenty of 275/40/19's match. Not even sure they will fit...
Update 2: Going to a local shop to get a test fitment and measurements done so we can figure out what the correct thing to do is.
Update 3: So, it looks like you can fit +30mm offset wheels no problem. The tire sizes I wanted Front: 245/45-19 / Rear: 265/40-19. But, you won't be able to find a matching set of tires in this configuration. I could try going up to 275 tires but then you might have clearance issues. The shop thinks that the inside of the tire will rub, in which case you'll need to get a spacer. And even worse case scenario is that you'll have to roll the fender.
I also learned today that an extra set of TPMS sensors is $500 and having Tesla code them to the car is $150 or so!! Geez.
Gotta do cost analysis to see if style is worth the hassle. The wheels I'm putting on are Volk LE-37A's for anyone that cares. Classics.
Update 4
In Summary:
Specs:
* Front: 245/45/19
* Rear: 275/40/19
Update 4
- Switched to Continental DW. Front: 245/45-19 Rear 275/40-19
- No rubbing issues. The A/S tires rubbed in the front when I went in reverse.
In Summary:
- +30mm offset wheels are fine
- This is a staggered setup: front 8.5", rear 9.5"
- Front: 245/45-19 Rear 275/40-19 fit without a problem.
- I'm running Continental DW tires. I had Michelin A/S tires on and the front rubbed when I reversed and turned the wheel 90% of the way in one direction.
- TPMS sensors are $500, coding at Tesla is $150ish but they did it free for me one time
