Wind noise in full glass roof new Model S
Discussion in 'Model S: Interior & Exterior' started by Patroradio, Jan 24, 2017.
  1. Patroradio
    Patroradio Member
    Montreal, QC
    Has anyone else experience disturbing wind noise in the cockpit of a model S with the new full glass roof? I can't say I hear air actually getting in the car, but as soon as I'm going faster than 65 mph, and especially at 75 mpg, I feel the Tesla is louder than my Infiniti.. which doesn't quite make sense. Not quite the silent highway drive I was expecting (although it's absolutely silent and awesome at low speeds). Anyone has an Idea what could be done?
  2. Dax279
    Dax279 Member
    Calgary
    There was a post on this topic a few days ago with some responses.
  3. GregKo
    GregKo Member
    New Jersey
    I noticed this too. My previous car was a p85 with pano sun roof. I thought with the all glass / no sun roof option would be more quiet at highway speeds. Did you notice that between the windshield and the glass roof there is no gasket? There is a 1/16" gap across that area and I believe that is where the wind noise is coming from.
  4. NAVALARCHITECT
    Southern California
    I get mine Saturday, ordered with the same full glass ... willsee how it is
  5. GregKo
    GregKo Member
    New Jersey
    You will hear it at highway speeds. I bet a simple gasket would help a lot.
  6. wattsup
    wattsup Member
    SF Bay Area, CA
    What do you mean "a gasket"?
    Isn't there some kind of seal between the two pieces of glass?
  7. wattsup
    wattsup Member
    SF Bay Area, CA
    Possible just to fill it with some silicone seal?
  8. Vortexx
    Vortexx Member
    Orange County
    I started a post on this exact topic a few days ago. I have the same issue. On my car, the glass roof is not quite flush with the trailing edge of the windshield. It is raised by a couple millimeters. I put a piece of masking tape across the intersection of the windshield and the glass roof, and it substantially improved the noise. My car is at the service center now, so we will see what they say. I was unable to find another car with a glass roof to compare mine to, so I don't know if the windshield sticking up slightly is within tolerances. I am confident that a rubber gasket that would fill the gap would solve the problem if they cannot make the roof fit perfectly flat.
  9. GregKo
    GregKo Member
    New Jersey
    On my S, the windshield and roof form a nice curve. There is a gap between both pieces of glass. They look aligned but its this gap that seems to create the wind noise. I am anxious to hear what the service center says about a possible fix.
    I would not silicone that area. 1) it might look bad and 2) that area needs to evacuate water once inside. I think a gasket that just covers the exterior but leaves a channel where water can flow under it would work.
  10. Vortexx
    Vortexx Member
    Orange County
    I picked up my car from the service center today. They acknowledged the problem with the roof noise (and have seen the problem several times already) but they did not do anything about it yet. They said that engineering is aware of the problem, but there is no permanent fix yet. They said that they have been putting silicone caulking in the area to solve the problem but admitted that it was an inelegant solution and they will probably come up with something better. So I said I would wait. In the meantime I went to Home Depot and found some rubber molding and press fit it in the gap. Here some shots of what I did. I cut the molding in Half and just used one half. After removing the backing, I folded the molding in half, using the sticky tape to keep it folded. I then slid it in the gap with a butter knife. It took about 15 minutes total. Not perfect, but sufficient until they come up with a better solution, as it is easily removed.
    • Like x 5
    • Informative x 4
    • Helpful x 2
  11. wattsup
    wattsup Member
    SF Bay Area, CA
    Seems like a big gap like that would create turbulence/noise. It is possible that it also decreases range (however slightly)?
    How did Telsa miss this?
  12. NAVALARCHITECT
    Southern California
    @Vortexx did you notice the moulding helping at all?
  13. ICUDoc
    ICUDoc Member
    Sydney NSW
    Yeah, looks really pretty good, quality DIY.
  14. Maximapolak
    Maximapolak Member
    North NJ / SouthCentral PA
    Looks factory...I like it!
  15. Skione65
    Skione65 Member
    Kentucky
    You'd think Tesla would 'Wind Tunnel' test this before release? After all the all glass roof was a new design...what just design it and throw the glass on and see what happens? Where in the world is they're R&D? Mars? :)
    Ski
  16. croman
    croman Active Member
    Chicago, IL
    My gap between the glass and the metal body is not that large. There is a gap but the glass is lower than the body (not sticking out). I only hear wind noise above 75mph and its not that bad (though maybe I am not particularly sensitive to it). I think a rubber gasket is a great idea but I do wonder about water pooling and creating issues without a proper drainage channel. Currently the gap seems to serve this purpose. Filling it with silicone might help as silicone is water tight but I also want to ensure the glass and metal body have the ability to contract and expand with weather changes (which are severe in Chicago). I'll wait for Tesla to address any issues.
  17. Maximapolak
    Maximapolak Member
    We're their guinea pigs. It's something new, and usually the first batch of things have some problems.
    Like you, I do not hear wind noise coming from the glass roof. my front windshield if flush with the roof with a minor gap.
  18. Snow Drift
    Snow Drift Slip Start: [Activated]
    Long Island
    Subscribing for a future owner of a glass roof.
  19. Joe F
    Joe F FUD Buster
    Willow Grove, PA
    I heard it too. Turned the radio up louder: Problem solved. :eek:
    Needed to investigate, but forgot to. Thanks OP for the reminder.
    Like the @Vortexx temp solution. Well done!
  20. Patroradio
    Patroradio Member
    Montreal, QC
    I'll talk to my service center and see if I can test drive my own car vs another car with them. I'd be curious to test with everything else (ventilation and music off) and a decibel-meter.
