I've had an issue several times now where using the defog button increases the fog build up on my windshield significantly to the point that i can't see out the front while driving. I'll turn defog on at the slightest hint of fog buildup to try to preempt it but then this happens and driving with my head out the window or trying to pull over till it clears up. Once it builds up it still takes a couple mins to clear with defog running and all my windows down to help. Brought my car into service a couple months ago and they said my HVAC is working correctly and to make sure i use defog(cooling) and not defrost(heated) and try to video record it if it happens.
Took my car into service today along with the video and they said the same thing, that my HVAC was tested and working correctly but they saw from the video i was using the defog(cooling) setting and said that i need to use the defrost (heated) setting.
I know you're generally supposed to use cold, dry, a/c air to defog the inside of the windshield the quickest and i have never had this issue in my previous 2020 Model 3 or other cars.
Has anyone ran into this issue or have any suggestions? I'm also located in SoCal so the weather isnt too extreme and this generally only happens on cold nights.
