Michelin ice3
I think they were pretty reasonable on cost for the TPMS, like 60-70 dollars per sensor? Just make sure you get the right kind, there were two kinds for Model S. They changed brands late 2014.Thanks, those look like they have pretty good reviews and even have a low rolling resistance rating. I'll probably get those. Anyone have any idea what Tesla charges for new TPMS sensors and center caps?
Nokian have two wear bars. One for snow and one for rain etc.
My understanding:
Nokian HakkaR2 best for cold, snow, iceVerify Tire Wear / Nokian Tires
Mich X-ice3 best for cold and slush
Pirrelli best for spirited driving in cold
Others cheaper and last longer.
UPDATE: Just looked. Not on my Nokians. I guess that was added sometime after 2014??
My understanding is that you should not use them for winter when the snowflake is gone. Of course, since there are no "snow tire wear bar" regulations in North America, it's advisory only. Some areas outside of North America enforce it.I'd have to go out and look at mine, but I recall something about a snowflake icon in the tread somewhere along with the more traditional wear bars. When the snowflake is no longer visible, they are not as good in the snow, but still serviceable as long as you're not down to the wear bars. Can anyone confirm this?
Nokians doesnt handle all that well on wet asphalt . You need to inflate them to 50 psi and take it more slow.Winter is looming and I'm pondering my options. I've run Nokians for the past two seasons but now I'm wondering if I should chance a third year on them. When new: TeslaPittsburgh.com: The Winter War - Preparing for Battle - Part 1
Unfortunately, those two winters were relatively mild here in the 'burgh, at least for snowfall if not temperatures. I don't think we ever drove the car at temps above 60 degrees, but the nonetheless, the tread wear has been higher than I expected (maybe 7000 miles on them). I'll take responsibility for some of that (my other 3-season Primacys didn't go far either), but generally I felt the Hakkas were pretty much horrific on rainy/wet roads... which is mostly what we ended up with.
So... I guess the question is, at what point do you retire snow tires? Mine aren't to the wear bars but they ARE snow tires, so I assume that isn't as relative a metric (thoughts?) Given that generally our roads aren't as arduous to traverse as yinz guys deep in the land of Canadia, would the Michelins be a better option with longer tread life? I think I could get those through Costco too. My plan of inaction at the moment is to just limit the Nokians to actual storm use and swap them off when we're generally in the clear, to try and eek another year out of them. Rumor has it that THIS is the year of the big snow storms-- but then I've heard that before!
Just finished a similar switch out, so I wanted to share a couple of items - I have a 2014 Model S85:This is my first winter with my Model S. I'm looking to change my wheels from the 21" (P245/35R21) summers and put on the 19" wheels with new winter tires (nokian hekkaR2 P245/45R19XL). Is there anything I need to do in the settings when I make this size change? Thanks!
Not in my experience. I had a 40 mile (each way) commute and our winters here see a lot of wet highways. I found the wet traction to be excellent. They will be going back on for their 4th winter very soon.
