View attachment 270954 View attachment 270955
Went up to 20” replika 187 with Pirelli Scorpions. They look nice.
In the two tire swap seasons, it's all hands on deck at the tire shops... you definitely have to stay on top of them, because some of the guys they pull in don't have much experience...Kaltire made a mistake of putting the 275/45/20 on the 20x9” rim and 265/45/20 on the 20x9.5” rim.
I haven’t heard anyone poop on the Sottozero 3’s. The thread on them looks like it should work well on snow.A number of people [poop] on the Pirelli Sottozero 3 tires from Tesla, but I drove through the worst of the storm on the 24th and last week on snow, slush, and wet highway roads and they performed flawlessly. I swear they are quieter on dry roads than tires that came with the car. I even pushed it on a corner without slipping.
I previously had Gislaved Nord Frost 5 winters on my Jetta then Golf, which were really good but these feel better. Especially going through the piles between lanes on the highway (heavier car helps too i suppose)
YMMV (literally and figuratively), but I’m happy with them.
19" for model S should fit model 3 too.@Mad Hungarian Any update on Fastco availability of Model 3 compatible rims?
Absolutely, if you go to our website you can now look up all available wheels directly for Model 3 and even see what they look like on the car with our iConfiguator app.@Mad Hungarian Any update on Fastco availability of Model 3 compatible rims?
Correct. But we're going to make a Model 3 version of the Model S Turbine in 18" with the 5x114.3 pattern, will be available this fall.hmmm... Model S wheels have a 5x120 bolt pattern, but I believe Model 3 uses 5x114.3
For Canadians looking for simple winter steelies that fit model 3, I found a good match here.
- Wheel is 7.5 wide, which is minimum acceptable for 235/45/R18 tires. The narrower wheel gives plenty of cushion in case one mildly touch winter icy curbs (not the case with OEM 8.5” wide rims, that would get scratched touching the curb)
- 5-114.3 Bolt Pattern, 64.1 Center Bore, +42 Offset –perfect fit for model 3
I bought a set of those recently and planning to mount them with XIce3 with Schrader programmable TPMS EZ-Sensors when winter comes!
Two things I'd want to check to be sure before proceeding with those:For Canadians looking for simple winter steelies that fit model 3, I found a good match here.
1. Is the lug seat conical (straight taper) or ball (rounded)? Very often steel or alloy wheels with a 5x114.3 pattern and a 64.1 mm center bore are designed specifically for Honda and Acura applications, which all have ball seat lugs. If so, you'll need to switch to some 14x1.5 mm ball seat nuts (the same as used on Honda Pilot & Ridgeline or Acura RL & MDX models).
If it is however conical, you will be able to reuse the OE Tesla lugs.
2. Do they clear the Model 3 brake calipers? The front calipers on Model 3 are not particularly problematic, but being a 4 piston monobloc design they do protrude outwards somewhat more than standard floating calipers on most cars. Be sure to test fit them thoroughly in both the front and rear positions before mounting up the tires.
I certainly won't debate the aesthetics of steel wheels. But, beyond cost (I paid 75$ for each), they have the benefit of bending rather than breaking when one hits a massive pothole. Especially given that the model 3 has no spare wheel, it could be the difference between being stranded and carrying on to your destination. And massive potholes are quite popular at this time of the year up hereIs there nothing else that fits the Model 3? Seems like quite a shame to drive around on those rims for half the year with such an amazing looking car. I hate those steel rims.
I am not sure if there is even much of a cost savings because nowadays there seem to be alot of good (and reasonably priced) options.
Good stuff, looks like your OE nuts will work.That is very informative Mad Hungarian.
1. I went and look at the lug seats, which are very narrow, they appear conical (cheaper to machine I guess).
2. Whether they will clear the rear calipers remains to be seen. I will know in 3 to 7 weeks. I have yet to hear someone reporting a 18" wheel not fitting on model 3 because of caliper clearance (heard a lot about the 17 inches though). So I cross my fingers...
