So in the heat of middle summer, you guys are already talking about winter this year??
Yup I’m starting to see Christmas decorations in the box stores. Gotta plan ahead..... I guessSo in the heat of middle summer, you guys are already talking about winter this year??
Costco has had the winter coats out for a couple of weeks now. Gotta be prepared.So in the heat of middle summer, you guys are already talking about winter this year??
After a lot of debate, I decided to go with a separate set of mounted snow tires so that I could do the swap myself every year. I also wanted a 19" set.
I went with TireRack:
19 x 8.5 wheels, Sport WX5
265/50R19 Bridgestone Blizzak DM-V2 XL
TPMS valves
Package total was $1875
I was able to save a little on shipping by picking them up at the Denver distribution center. (fitting 4 tires in a 6-seat MX was easier than expected!)
Photo below. Ignore the blue center cover...that is protective plastic. The cover matches the wheel's Titanium Gunmetal color.
The performance in snow was excellent.How was your winter tire performance last winter? I am looking at getting a set for my X too but the Sport WX5 has only 28mm offset comparing to 35mm offset of Tesla Cyclone wheels.
That's odd. I ordered TPMS with my Blizzak + rim order from TireRack and they worked perfectly.When I build out a tire and wheel set on Tirerack it says that the site says that they don not have TPMS modules.
I see that folks on this thread bought from Tirerack. How did you handle this?
It is usually not recommended to remove tires from the wheels, as it could damage tire sidewalls and wheel rims. But changing just the tires can be done to save money.From your experience, is it ok to just buy the winter tires and switch them on the same set of rims each season? That is how I usually proceed so I don’t have to buy a second set of rims. Are Tesla tires special in that matter? More complicated to switch? Etc.?
Thanks
A number of folks do this. You will, of course, need two different size tires for the front and rear.From your experience, is it ok to just buy the winter tires and switch them on the same set of rims each season? That is how I usually proceed so I don’t have to buy a second set of rims. Are Tesla tires special in that matter? More complicated to switch? Etc.?
Thanks
You can call them...they have great, and helpful customer service and you can place the order over the phone at yth same price.
Tires have been great for winter driving. The amount of wear appears normal but I don't tow a trailer and no hard acceleration or braking
My rationale for buying mounted tires is that I can swap them myself. And by going with 19" winter tires, they are all one size and can be rotated for better life.
Thanks!
What would be the best jack and wrench for my X? Any suggestion?
Is it weird that I’m all excited about changing tires on a car? I have never been a car person
I use a 3-ton Pittsburgh floor jack from Harbor Freight (model 61253).Thanks!
I also built a jack pad that fits the model X hole pattern using plans that someone posted on this forum. You may have to search for that thread...I don't think I bookmarked it.
And don't forget to remove the lug covers first with a cover remover, or needle nose pliers...Thanks. I’ll look the jack up. For the adapter I already bought this one: Vendor - Tesla Model X tire service jack pad adapter
Then I’ll need a good wrench with a torque adapter.
