This is not related to Tesla, but it might help people that are in the process of setting up charging systems with help of an electrician.
A level 2 wiring might require a wire to connect the plug (14-50P for mobile charger) as used by an electrician or a dryer adapter. The issues are that most of these items are in short supply and out of stock, and they are now offered by on-line shady operators.
Wire: ROMEX 8/3 (used by the electrician to connect the 14-50R for the mobile charger) is mostly out of stock in the San Francisco Bay Area. I found it on line for a similar price as the big box retailers, but it turns out that the sellers seems to be scammers. For example, ‘neemomart’ in Richmond, Virginia claims to have 17 ’25 bundle’ in stock, but after debiting my card, they did not answer any email or call. A search of the local BBB shows that ‘neemomart’ is probably a scam. Other outfits offering ROMEX 8/3 similarly do not answer any call: ‘ikaad’ from San Francisco, ‘fastenane’ from Carlsbad CA & ‘amazeo.shop’, etc. Be aware of the ‘on-line wire scams’.
Adapter: a stop-gap level 2 charging uses a dryer wiring (eventually through a splitter) terminating to a 10/30R receptacle (in older house) that requires a 10/30P plug to 14-50R adapter plus a grounding wire. I successively ordered these adapters from 3 on-line sellers, but they all refunded the purchase. While this is not a ‘scam’ per se (I got my money back), advertizing ‘in stock’ for something that is not deliverable is at least false advertising. In any case, I am left without an adapter
