"no it's not." - The Forum
there are countless threads and posts that say the SR+ will "only" charge to the 210-220 range when it reaches 100%. it's no surprise the non-plus/standard SR only gets 200. these are estimated ranges anyway. as much as I hate it, the number and the misconceptions about what these cars ACTUALLY charge to/get in terms of efficiency are the real problem because there just isn't a 100% way to show a value.
your phones don't say "YOU'LL GET 10HRS OF USAGE TODAY!" Android started to show "...should last until... with current usage", which is completely different. ICE cars don't advertise RANGE. they advertise ABOUT what you'll get and you can do the math from there. EVs really need a different method.
EVs advertise range because it was the easier thing for consumers to understand, for better or worse. I can tell most people that the EPA rating is 500km and they'll understand, but 150Wh/km (more equivalent to an EPA rating involving mpg) is utterly useless to them. Heck, it's still kinda useless to me honestly other than a relative comparison from drive to drive. The gotcha with EVs is there's many more ways for them to lose charge versus a gas car's fuel.
While it can vary a little until some lower threshold, the rated miles on these cars is a fairly good proxy for available energy. If you are displaying rated miles, you are in a way displaying available energy. When you charge to 100% and the available energy is lower than before, that
is indicating
something, and cannot be explained away by inefficiencies or heating or any other thing involving a unit of power. Thus, it is actually
indicating a reduction in battery capacity. Whether or not it's temporary (cold, BMS out of calibration) or permanent (simple capacity loss / degradation) is the important thing to know.
If people are reporting 210mi @ 100% on an SR+ rated to have 240mi @ 100% at the time of sale, I see a
potential problem (if it's early days for the car, which most Model 3s are still). Maybe it's common, but if it's a trend it's an actual problem. Going by what the customer can see alone, that's a 12.5% drop that happened rather quickly, even though Tesla used to (maybe still does?) account for initial losses by doing some number tricks to make the first few percent degradation not visible (i.e. it will initially lose capacity, but still display 240mi anyways because they baked in an assumed loss but displayed a max of 240mi anyways).
That said, from what I've seen on this forum there is no trend. They seem to drop 5-10% and then just sorta stay there, apparently?
