I'm not sure I understand the question - are you asking if anyone is seeing permanent degradation, or if we're seeing a consistent vampire drain?Anyone getting permanent battery charge drain?
And mine is 250 vs 257 originally. This after 12k miles and 10 months of ownership.Do you mean permanent reduced range/capacity? If so, yes. My 100% is 210 vs 213 originally. I've lose 3 miles over 6 months.
Seems to vary. My 3 year old 85D with 37k miles has less apparent degradation, though.Is that normal? Seems significant to me. Mine is 4 miles after 10k
I received delivery of the Tesla X 75D 3 weeks back & have set the charge limit to 90% but am only getting 300km max typical range. I feel it is a bit less. Is this normal? I called Tesla & they said the car is giving the range based on driving habits & it will change with more data. Anyone else getting similar range of 300km for Tesla X 75D? I need to charge every 3 days![]()
Forgive me if this is a dumb question, but where are you all getting these numbers from and how do you know what 90% charged is? I don't seem to remember a setting where you can select the charge percentage. Only a slider where you can select where to stop charging. Are you figuring out the 90% from this? Also, where are you getting the mileage information from? The charging screen after the charging is complete? I wanted to compare my car with what other people are posting but I'm not quite sure what to compare.
Thanks.
Also, if push notifications are enabled on your phone, the "charge completed" message will show the mileage at the exact time it's done.90% is where the slider snaps to at the daily level. For most accurate read make sure you have it set to rated, not ideal, miles and read right when charging completes (avoid vampire drain).
X 90D, 1/16/2017 delivery
After delivery: 90% 234mi / 100% 260mi
After 9,272mi: 90% 232mi / 100% 258mi
