If it’s cold enough, regen doesn’t even exist so it’s really not a backup to the hydraulic system. I see your point though.if you are having to stop a car moving at 30mph+ that has lost hydraulic brakes AND regen braking you are certainly in a world of hurt![]()
Does hold mode use the parking brake or does it have some other magical way to use the hydraulics?
The electro-hydraulic brake master cylinder, and possibly the drive motors (easier to implement with 3 style)
Yeah, it's not a very controlled application at that point.If it is absolutely necessary
I heard (and this is not substantiated by any documentation) that HOLD mode is ONLY the electric motors holding the wheels in place - no brakes.
HOLD: Maximizes range and reduces brake wear by continuing to provide regenerative braking at speeds lower than with the Creep and Roll settings. When Model 3 stops, the brakes are automatically applied without you having to put your foot on the brake pedal. Whether stopped on a flat surface or a hill, Vehicle Hold keeps the brake applied, provided your foot remains off the accelerator and brake pedals. See Vehicle Hold on page 72
When Model 3 is stopped, Vehicle Hold can continue to apply the brakes even after you remove your foot from the brake pedal. When driving on a hill or on a flat surface, brake as you normally would. After coming to a complete stop, simply press the brake pedal again (until the touchscreen displays the Vehicle Hold indicator light) to enable Vehicle Hold. You can then release the brake pedal and remain stopped, even on a hill.
Note: When Stopping Mode is set to Hold (see Stopping Mode on page 66), Vehicle Hold engages automatically whenever Model 3stops while in a driving gear. There is no need to press the brake to engage it.
There are other improvement opportunities that follow the same pattern. For example, navigate on autopilot should be lit up blue only when functioning, outlined in blue when set as default and grey when off and available and white or something when not available.I will admit, I do find it confusing that the ((P)) icon ONLY appears when you manually apply the parking brake. IMO it should always appear when the parking brake is set.
It seemed like a very quick and uneventful stop-I timed it at about 3-4 seconds from 54 Km/h (probably Km rather than miles). I was impressed considering it is screw action rear braking. I tried translating the captions and it was strange.
Yes it's in Italian language, go directly to around 2:30 to see how the car brakes pushing the button. There are many others attempts during the video
- Would having an additional parking brakes on the front wheels would have been of any help?
Bad tires and/or parking on a slippery incline surface could cause this problem with almost any car. I can't think of any vehicles that lock the front wheels with the parking brake, it's often a rear drum brake style setup for manual parking brakes, and a rear electronic screw types for electronic ones. Note in this case the cars rear wheels were almost certainly not spinning, hence the problem isn't the brake.Just to add to the fray: Tesla slides down driveway with my kid still inside.
Note: I can jump to 0:53 to see the car sliding back and avoiding an other car.
This is common sense, so if your driveway is inclined you should turn the front wheels or put a wheel stopper.Bad tires and/or parking on a slippery incline surface could cause this problem with almost any car.
Still many people turn their wheels in the wrong direction..., and also your wheel has to touch the curb.
It should be common sense, but I'd disagree that it is in fact common. Many people seem to have the impression that a parking brake can defeat the laws of gravity and will forever prevent a car from sliding. This is one reason why plowing/salting or sanding your driveway is so important in the winter.This is common sense, so if your driveway is inclined you should turn the front wheels or put a wheel stopper.
Well, in San Francisco you get a ticket if you don't turn your wheels towards the curb on a grade steeper than 3%.
And some streets are so inclined that you have to park perpendicularly to the road.
