A lot of AC units are allowed to be attached to breakers up to 50A, but if you actually measure the current while they're operating, they're only drawing about 12-18A (for ~3 ton units).Get the model number of that AC. It probably only has a 50 amp breaker for the motor-start current. Figure out what that 30 amp 240 volt breaker is driving, most likely a range or clothes dryer, and see what IT is rated to actually use, worst case.
Any superchargers near you?Hey guys! What are my options here if I don't want to upgrade to a 200 amp panel? Thank you!
I'm not an electrician, but OP's panel does not appear to be an Eaton/Cutler-Hammer. The shape/proportion of the breakers appears wrong.tandem breakers will fix your issue
Eaton BQ230250 Circuit Breaker with Rejection Tab, Quad, Type BQ, 30/50 A, 4 -Pole, 120/240 V
Buy Eaton BQ230250 Circuit Breaker with Rejection Tab, Quad, Type BQ, 30/50 A, 4 -Pole, 120/240 V online at DKHardware.com. Our Pool & Patio category offers a great selection of Circuit Breakers products at the best price!www.dkhardware.com
replace your 50 with this,
give your tesla a 30 240v outlet and your set, this is what i did. Feel free to DM with questions, I used to work as an electrician.
More detail about my panel. Can I use tandem breaker on this?I'm not an electrician, but OP's panel does not appear to be an Eaton/Cutler-Hammer. The shape/proportion of the breakers appears wrong.
That's sorta why I asked for a panel model number in comment #2
You're very fortunate if you can do a service upgrade for less than 5 figures. This usually means that you have the service line overhead; I had to pay $7000 just to have someone install the new service line and conduit. And then another $2500 or so to do 400A service instead of 200A because I wanted to make sure that I never had to pay someone $7000 to install a conduit again.@Jasonb2710 I ran into the same problem and got several quotes from switching to quad breakers to a 200amp service upgrade. The cheapest non-permitted work that anyone would quote me was about $700 to add a 50amp breaker and install a NEMA 14-50 outlet. A service upgrade would have set me back at least $4000.
