I have one. It has the same problem. Charges at 15/16A when the car reports 16A, again which did pull 16/16A before a July software update.
Weird. I always get 12/12 or 16/16 at 120 volts, and all of my other adapters give me the full rated amount too. In my case, it is just with the odd 80 amp J1772 station in combination with my J1772 adapter that will give me 79/79 for some reason. Tesla even loaned me a couple of J1772 adapters to try, but they all gave me 79/79 at the suspect station that worked fine at 80/80 for other Model S's.
Where are you measuring amperage? What is your software version?
My Model S is running 8.0 (2.46.16) and I was referring to what the car is displaying.
About 2 years ago, I had it plugged into a Kill-o-Watt type of meter at a friend's place so I could show him how many kWhrs the car was using, and it was showing 12 amps when the car was showing 12 amps. I only did that once.
I have a TED energy meter at home, and my car and the TED do match there when I'm charging at 240 volts. (I have to do some math to calculate Amps because the TED shows kW and Volts).
So, if you use a NEMA 5-20 plug plus a third party 5-15 adapter and plug into a standard circuit, and set the amps in the car to 12, will it actually be 12?I have one. It has the same problem. Charges at 15/16A when the car reports 16A, again which did pull 16/16A before a July software update. I've also made a NEMA 14-50 -> NEMA 5-15 adapter, that I can have pull a real 16A on either 110V socket. But that's obviously dangerous because sometimes the car will reset the limit.
Are you ever tempted to set it to 13A, or 14 even? I know you aren't supposed to draw more than 80% but I happen to know the plug I use has nothing else on it, ever. I charge at work on a plug in the garage and barely get my commute mileage each day, and pay exorbitant rates to charge at my condo. If I could add 10-20% to my daily charge at work it would be great.Yes.
Sorry for the double chart. If that wasn't clear, this should be:
Interesting. As I say, the last time I actually metered it on 120 volts was probably 2 years ago (when it was consistently 12v on the meter and in the car). That was obviously many firmware versions ago. I pulled out my Kill-o-Watt and found the LCD display is shot (even tried new button cell batteries in it), so have no way right now to test myself.
Although, I do have one of these and could plug into my 14-50 and meter it on my TED....
It's clearly a bug, and it affects people like me. I charge at work at 120V, every single day, and get pretty much exactly my commute mileage. This 1 amp over the course of my day, every day, adds up. Just seems like a simple bug to fix yet it has not been...I can't believe there are 55 posts about a discrepancy of 1 amp. But this is TMC, so maybe I should believe it.
Do you have the 5-20 adapter? Most 120V outlets at commercial properties are 20A. Charging with that adapter at 16A (or even 15A) is significantly better than charging at 12A, whether it's really 12 or 11.Making someone's charging between 7 and 11% slower on the most common outlets in North America sucks, and that could be significantly worse if the pack heater needs to turn on. Sometimes there is no choice. I'm going on a ski trip this year and the only option is 110. I didn't book the lodging so it's either don't take the Tesla (and show everybody how impractical EV's are), or try and get enough juice on 110.
I think Tesla did this on purpose to walk back 1A from all UMC charging, the software explicitly reports incorrect amperage at only rated amps. How could their software validation suite NOT include testing actual current draw?
