Can anyone please answer the question about what AWG these wires are? (I don't have the car here to look.)
2mmCan anyone please answer the question about what AWG these wires are? (I don't have the car here to look.)
Metric wire sizes are cross sectional square mm, so while #12AWG has a diameter of 2mm it is #14AWG that has a cross sectional area of 2mm. The proper answer is #14AWG
Error 1146 came back recently.
The servicecenter was not able to correct the error during my recent yearly maintenance. ( even after several days)
So I performed the old trick again :
Cleaned out the 4th connector underneath the PEM. ( connector to the right)
When you remove the rear pem panel in the trunk you can reach this connector without have to remove the PEM.
I cleaned the connecter with a vacuum cleaner - put it back on - and beye beye 1146 error's !
In the mean while I ordered some WD40 electric contact cleaner ( WD-40 Specialist)
, I'll be using this if the error comes back in the future.
Pulling the fuse cover off the PEM disables the APS automatically. Not that I recommend that method of disabling the high voltage...I pulled the fuse cover off the PEM and while I would not recommend it to anyone I was desperate to see if my charger had plowmen the PEM fuse. There was no power to the PEM but I guess there could have been. I’m assuming disabling the APS stops any way for the Can bus to close the contactors.
if you just want to "reseat" the fan connector , no need for unpowering the PEM I believe.I wondered, as I have the same messages after been to the SC if this might be a case of proper reconnecting...
do I need to "unpower" the PEM as written in the DIY PEM cleaning?
DIY: Roadster 2.5 PEM cleaning - step by step
I would be glad for a reply. many thanks
thomas
Step 5: Clear the Ductwork of Debris
Time to clean! If you have an air compressor with a long handled nozzle, you're in good shape. Set the regulator to 80+ PSI as you'll want to try and dislodge as many leaves, dirt, and whatever else is lurking in there with strong blasts of air (Vid. 3).
Thx again to everyone for your input and guidance! I truly hope the steps above addresses this error once and for all![]()
Yes, the thermistor is on the cooling plate. When you drive hard the IGBT’s will produce a lot of heat, you are measuring the heat transference to the plate and it should, if there is adequate air flow, cool fairly quickly, without good air circulation and debris accumulation the heat will stay in the plates and take a long time, If ever to cool down.
this is where I believe you are reading temperatures from.
