So if you opt for the larger 19" wheels, you currently get Continental ProContacts (Tire Rack link: https://www.tirerack.com/tires/tire...X&partnum=34WR9PCRXXLCOSI&vehicleSearch=false ), which are specced on the door jamb to be run at 42psi.
Am I the only one who's not happy with the lack of grip this combo has on the road? I know Model 3 is quite torquey, but even so on uphill tight curves I can make the tires slip quite easily. The Model 3 I followed on Skyline a month ago also spun the tires on a tight right turn, which I attributed to some gravel, but now I'm thinking even without the gravel it would have slipped.
On Tire Rack's site, they're described as "for drivers who want a combination of a sophisticated appearance, competent handling and H-speed rated (or higher) durability, along with all-season traction, including in light snow." I bolded the phrase that gets me - I want more than "competent handling."
Any ideas on how to improve this? Anything from letting some air out of the tires to running a different brand/size to even going with different wheels is something I'd consider. BTW, these tires at $279 each aren't cheap.
