Well I do not have a clue on the short term SP movement, as
I really do not have a clue what TSLA will do on Monday, but inspired by my good guesswork on Friday, I am going to opine nevertheless.
I think that we have a pretty well established (pink) symmetrical triangle pattern on the daily chart, so I continue to look on SP movements in this context. We had a clear failed breakout, thwarted by the bear attack which brought us right to the upper support line of the symmetrical triangle which on Friday, coincidentally, met up with the support line of the extension of the regression channel TSLA followed 8/21 - 9/11 (light blue). This, BTW, was the basis of my successful call on Friday.
So I think that Monday TSLA will test the support line of the pink triangle again. If this support line stands, I think that TSLA will go into the (brown) wedge, eventually successfully testing $390-ies, most likely coincidental with some good news - either Q3 deliveries (just to make sure I do not believe that we can make a call on that - so just hypothetical), or Semi event, or ER call.
If TSLA is not able to hold the (pink) triangle support line on Monday, I think that SMA(100) might not offer much support either, and the bottom line of the pink triangle will quickly come into play...
***Not an advice from the low ranking member of the Asylum for delusional***
