I posted in the other thread, but I'll just copy and paste into this thread since I'd love to hear from fellow AP2.0 folks (for the record I have service appointment scheduled for 1 Apr to look at this):
I just got the update moving from 2018.50.6 to the 2019.8.3 and after it updated like others mentioned, no release note PLUS now I have an error when I put it into "D" I get the error "Blindspot Detection Limited Visibility..." with the yellow warning triangle. So no cars display to the sides of me.
I've wiped the lens of the side repeater cameras and even the B pillars but to no avail.
When in Park, no error messages.
Put foot on brake, shift to Drive: Yellow Exclamation on Instrument Panel/Gauge cluster stating "Blindspot Detection Limited, Camera Visibility Reduced". On the MCU screen, there's a red ! mark in a circle. If clicked, it states the same thing but with a Red Triangle.
I had no error messages this morning on the drive into work prior to the update. I decided to have the car update at work while sitting in the parking lot. Came out to go to drive to lunch, and surprise! No more blindspot car images and a warning message on MCU and IP displays.
Also, if autopilot is engaged the error message goes away but it doesn't show cars behind or to the side of you. If you use the turn signal while in autopilot another yellow triangle message displays that auto lane change is not available. This means you'll have to manually disengage autopilot, change lanes, then re-engage. This also obviously means no NOA.
Car is Oct 2016 75D with EAP/FSD AP2.0
ALSO: Phantom braking (brakes for no reason, not predicatable like the occasional overpass or bright sunlight issues) and hesitant performance with cars showing up from on-ramps.
Bottom line, be glad you don't have 2019.8.3 if you're on AP2... it's not like we're even getting Sentry mode for our troubles!
