MarcG
MF4400What's your VIN? I'm trying to figure out what range got the crappy yoke.
What software version are you on? That was fixed in a recent update.MF4737xx. No yoke noise. But I do get this strange cooing noise every 10 seconds behind the main screen.Sounds like something is activating or rotating at fixed intervals. Very annoying.
Old SW: 2021.43.202What software version are you on? That was fixed in a recent update.
Also, did you mean NF473xxx for your VIN? Yours is a '22, right?
Oh man, I miss the DoveNF4737xx. No yoke noise. But I do get this strange cooing noise every 10 seconds behind the main screen.Sounds like something is activating or rotating at fixed intervals. Very annoying.
Edit ‘M’ in VIN corrected to ‘N’. Thanks @n2mb_racing .
It was a high point, when something was actually fixed in the software...Oh man, I miss the Dove
Interesting
My September Plaid is at the SC getting the Airbag Recall…
Just saw this on the invoice. Another recall? (Redesigned Wiring harness for air suspension?)
Concern: Retrofit Hydraulic Control Unit Wake-Up Wire
Correction: Retrofit HCU Wake-Up Wire
Parts Replaced or Added
ASY,HARN,FRUNK SWITCH GND,OVERLAY,MS(1731861-00-A)
Part Quantity 1.00
Correction. This apparently is part of the brake system -- the reference to frunk is just the location of where the wire harness is and maybe what else is on the harness, but issue is the brake HCU wake up wire -- needs to be retrofitted. I have a August or maybe July build, also needed the airbag (I wonder if I got the horn . . . )
Does anyone actually know for sure what this recall does? Also, they say it takes 1.5 hours for the installation. What are they removing to get this recall done?
2021 Plaid July Build.
Yes, hcu is a part of the brake system. No idea what the change was for.Hi! So, this is literally the hardest thing to find any information about. I have had one SC tech confirm it is tied into the brake systems. Can anyone confirm or elaborate more?
Are you able to break it down with a little more explanation of what it does?Yes, hcu is a part of the brake system. No idea what the change was for.
No idea. Something to do with the frunk switch mentioned elsewhere.Are you able to break it down with a little more explanation of what it does?
The dove went away for me but recently returned. Migration?Same.
‘Tis the season, after all!The dove went away for me but recently returned. Migration?
For the amount of work it will require, do not fix it. Mobile service can do it, but might be more than it is worth. And Tesla service might call it "within spec".A quick non-refresh question. Are the handles supposed to be absolutely flush when not presented? Mine are all at the same place, but all slightly below flush. Maybe 1/16".
Exactly. Tesla’s seem to attract OCDers.For the amount of work it will require, do not fix it. Mobile service can do it, but might be more than it is worth. And Tesla service might call it "within spec".
All that said, if your OCD is killing you - never hurts to ask.
I don't know, I mainly want to make a point that Tesla manufacturing should start delivering perfect vehicles for $150k.Exactly. Tesla’s seem to attract OCDers.
The more a tech messes with your car the more damage they can do.
Maybe it’s supposed to be slightly in and the ones that are flush are out of spec
I see people complain about silly stuff. Like a spec of dust in the instrument cluster. And let a tech pull the whole dash out to “fix it”. I wonder how many squeaks they have now.
I was thinking about this, probably because I’m obsessing
I think our cars are our modern day “Man Cave” Something we want to control and make perfect. And keep perfect with PPF etc. like putting a screen protector and case on a shiny new iPhone that we want to keep like new. Sorry just rambling… I think it’s funny though. Most of us are thinking the same way for the same reasons.
