My taillight modification has been completed, the picture is for your reference, the outer taillight and the inner taillight are plugged directly into the original plug, no need to change the line or use an adapter, the test function is normal, the turn signal, brake light, and reverse light are only on the right side On, the rear fog light is only on the left side, so that's it, and I'm quite satisfied, thanks to @Hotboy408 and other netizens for their support and suggestions!
Congratulations looks excellent. How did you do charging port?
