Bought the car in January and rear tires bald at 8k?
I have a 2020 MY still on stock tires with 53k miles. All 4 tires still good!
MY long range and 20 inch induction wheels. Even wear across the threadIs the 2023 a Performance Model Y? If not Performance Model Y what size wheels?
What brand tires came on the 2023 Model Y?
Is the rear tire wear even across the tread or only on the inner or outer edge of each tire? Uneven tire wear could be caused by improper camber.
Many times if you take the vehicle to an authorized distributor for the OE tires they can check with the tire manufacturer. The manufacturer may offer, as good will, a significant discount on a set of replacement tires.
??? Your message is very confusing.Bought the car in January and rear tires bald at 8k?
Sorry, wife has a 2023 MY Long Range with 8k miles. I took a closer look at it this morning and it looks like there is outer wear on the tire. Will Tesla cover a wheel alignment at this point???? Your message is very confusing.
Are you the person in the first sentence or the second sentence?
No. No manufacturer will cover an alignment unless an issue is reported immediately after delivery.Sorry, wife has a 2023 MY Long Range with 8k miles. I took a closer look at it this morning and it looks like there is outer wear on the tire. Will Tesla cover a wheel alignment at this point?
Guess it balanced out for you - really hit the Lotto with your 2020. I replaced mine at 16.5KI have a 2020 MY still on stock tires with 53k miles. All 4 tires still good!
Which is probably a contributor to your driving behavior and speeds. You should be able to easily achieve ~25,000 miles on these tires, assuming the alignment is accurate and spec’d.Guess it balanced out for you - really hit the Lotto with your 2020. I replaced mine at 16.5K
Are you saying your current tires have 53k miles on them? What is the tread depth? Google says (I assume EVs because of weight should not last as long, but I don't know)Bought the car in January and rear tires bald at 8k?
I could have stretched the OEM 20’s to 20K but the Goodyears suck, Michelin PS AS4’s are much superior. If some get high mileage more power to them, not worth it to me.Which is probably a contributor to your driving behavior and speeds. You should be able to easily achieve ~25,000 miles on these tires, assuming the alignment is accurate and spec’d.
Heck, there’s models for sale on this very forum with the original tires at ~40,000 with major wear.
No, I’m saying my wife’s 2023 Model Y Long Range with only 8k miles needs the rear tires replaced.Are you saying your current tires have 53k miles on them? What is the tread depth? Google says (I assume EVs because of weight should not last as long, but I don't know)View attachment 971061
Tread depth? I aspire to get as many miles.However, I also have a 2020 Model Y Long Range with 53k miles and all 4 tires are still good.
53K? I'd like to see photos of the tread depth.Tread depth? I aspire to get as many miles.
