Thought some of you may find this interesting:
I have an April 2023 Shanghai-built Model 3 based in New Zealand, and noticed the PWS speaker also does double-duty and makes the "horn" sounds too, as this car doesn't have the standard dual-horn arrangement located in front of the the left-hand wheel well area. The connectors are there but they're blanked off and there's no 12v present to them when the horn is pressed.
I don't yet know if this is due to being disabled via software, or whether there's a physical disconnection somewhere upstream from those connectors.
This is different to the 2022 and earlier cars, which still have the horns but didn't come with the PWS speaker installed (At least here in NZ). It's now a service installable item if one wishes to have it retrofitted.
My PWS speaker also has different electrical specs compared to the 2022 and earlier units. Mine is Part Number: 1671113-00-B and is rated at 50w/2ohms. Older speakers were 25w/4ohms. I'm guessing the higher power rating is to also make it louder since it makes the normal horn sounds.
