What would be the additional (complete/turnkey) cost of a CANBUS reader for a reverse signal?
Cost would be about $100 for the panda module (+maybe a few $ for the cable to connect it to the diag port... though actually, this maybe possible 100% via the OBD port... will look into that a bit more in the next day or two. panda OBD-II Dongle
Bravo, appleguru! I wish you the best of luck finding time to come up with a clean solution. I'm eager to get the camera switch, but not at all eager to have to run another wire to the rear of the vehicle to get the reverse camera signal. Fingers crossed, and thanks in advance for sharing your efforts with the TMC community.
Almost done with my initial code for this... you guys can follow along with my branch here: appleguru/panda
There are actually lots of CAN signals I can use for "is the car in reverse", so I need to do a bit more testing to which one is the best/if any are available on the OBD port.
I've borrowed an unused GPIO output on the panda's STM32F413 micro. It is logic level; off is 0V and on is 3.3V DC. This *may* work directly with the camera switch as is, or it may require a small transistor/FET to switch 12V... depends on how the switch circuit was designed. Once I get the switch @HankLloydRight shipped me, I can so some additional testing.
