Has anyone done the install yet on an AP2/AP2.5 car? I plan to do a preliminary install on my car this week (and take video of the process for you guys), but wanted to see if anyone else had any tips/tricks yet.
I was finally able to get a suitable cable for the "after autopilot" install from Tesla (namely, the Ethernet cable that goes between the CID and the IC: is is the same Dacar 535 cable type and has black HSD connectors on both ends, which will work to plug into the APE. CABLE, HSD, MCU TO IC, PN 1007779-00-D). The correct cable has a blue connector on the end that plugs into the MCU/CID and a black connector that plugs into the APE, but Tesla was not able to find this part in their system.
I modified the board @HankLloydRight sent me with a Z style connector I had lying around (was a cable connector and not PCB style, so is a bit sketchy, but should work for a test fine).I will report back (and share the video!) once I have everything installed and working.
Some brief updates on the camera switchers and CAN adapter front:
1) We were able to source Z style connectors for the camera switcher from the OEM. These have been ordered and should arrive in the next few weeks. I'll let @artsci chime in with any more details, but I believe these were the last outstanding parts needed for the switcher build.
2) @artsci has provided me with initial measurements for the required cables for the install. I will verify that these are compatible with AP2/AP2.5 in the next few days when I do my camera install. Once we have measurements compatible with both installs, we can order cables from the OEM vendor so you guys don't need to deal with Tesla's (sometimes not so helpful) parts departments and also so you don't have several extra feet of cable you need to stash away (fewer connections and less cable should make for better signal strength and ultimately more reliable installations). The only caveat here is that these cables have a pretty high MOQ (around 100pcs) and a relatively long lead time (around 8-10 weeks).
3) On the canbus front, @Kalud is making good progress on the rev B hardware design. I have the software for the core functionality done. While not strictly necessary for this camera switcher application, I am currently working on a LIN bus implementation for Panda which will allow us to interface with an NXP IO expander IC (UJA1023) and provide us with 8 additional outputs that we can use for various other applications. I hit a small snag with this NXP interface, and have a support ticket open with the vendor to clarify an implementation detail, so will hopefully hear back and have this also working by next week (which means we can finalize the PCB design and start ordering components).
We are up to 25 deposits for the CAN bus kit so far, which is great. If you are interested in one and haven't put your deposit in yet, send me a PM!
