So because I want to go whole home backup, my main service panel can't be used to shunt all 200 amps to a GW2 and then in turn to a 200 amp distribution panel. The reason is my main service has a max 100 amp breaker requirement.
So the upgrade will remove the existing panel and install a meter with a 200 amp line to a new 200 amp distribution panel which will be my main service panel. All the lines coming into the existing panel will have to be relocated. Fortunately the location of the new panel is a shorter distance for all existing loads except for a single 15 amp line which will have to be extended.
They haven't told me who the contractor will be but just got the preconstruction proposal which is $4200. Seems pretty steep for a panel upgrade that requires no trenching nor does it require upgrading the service line.
