Jordan Giesige:
"In the conversations I've had with Joe Tegtmeyer, his read of the mood of the cell team at Giga Austin is that they're "absolutely giddy"
Jordan Giesige:
So much possibilitiesWhy is the 4680 cell charge rate worse than 18650 and 2170 cells?
Tesla Cybertruck Charging Session on 800-volt charger reaches 327KW
Full charge curve available from the source:I am not sure how accurate this is:-
No mention so far of the taper rate...
They should make a range extender pack that uses all that extra space. I wonder if there's a reason they need an air gap between the top of the battery and the interior floor.
I could be wrong, but I think those risers are inside the cab, and allow storage space under the seats. (And for the rear passengers to have their feet extend under the front seats.)They should make a range extender pack that uses all that extra space. I wonder if there's a reason they need an air gap between the top of the battery and the interior floor.
The floor has a layer of styroform under the carpet for noise, thermal, ducting, and flatness.They should make a range extender pack that uses all that extra space. I wonder if there's a reason they need an air gap between the top of the battery and the interior floor.
They could use 46120 cells and add ribs inside the pack to get back the stiffness lost by removing the trusses on top.I could be wrong, but I think those risers are inside the cab, and allow storage space under the seats. (And for the rear passengers to have their feet extend under the front seats.)
Or are you just referring to the couple inches where the support bars go across the pack? (Which isn't enough space to put another layer of cells.)
Cross car interior ribs impact cell packing, electrical and cooling connections along with being a mating and integration nightmare.They could use 46120 cells and add ribs inside the pack to get back the stiffness lost by removing the trusses on top.
I feel like they must have had a plan on how to get 500 miles of range. I doubt the bed mounted range extender was the original plan.
But a box with no ribs isn’t very structural. It seems like the only advantage of the structural pack is that it’s easier to put the seats in the vehicle. It doesn’t look like it improves packaging much. They’ve simply moved the ribs that were on the bottom of the body to the top of the pack.Cross car interior ribs impact cell packing, electrical and cooling connections along with being a mating and integration nightmare.
I'm interested to see the packing arrangement.
The ribs on top were always there. Check out the 4680 and 2170 Y variants.But a box with no ribs isn’t very structural. It seems like the only advantage of the structural pack is that it’s easier to put the seats in the vehicle. It doesn’t look like it improves packaging much. They’ve simply moved the ribs that were on the bottom of the body to the top of the pack.
