AlanSubie4Life
Efficiency Obsessed Member
So 473 HP/495 torque now?
Not necessarily. They only mention HP, which just means a little higher peak current draw from the battery. They could just extend the flat torque curve a bit to higher speed and add to peak HP with no increase in “peak” torque. Based on the minimal improvements in stated 0-60 times going from 5.1s to 5s (for the LR or whatever), I suspect only peak HP is increased (which for the P3D would only change behavior above 45mph or so, where peak HP is currently reached). But we will see!
If they were to increase torque by 5% from 0mph to around 47mph (~ the new speed where peak HP is first reached), and roll torque off after that as they must to maintain constant HP as speed continues to increase, on the other hand, I’d expect nearly a 5% improvement. But they are probably not doing this.
