Looks like you might need two range extenders lol….
I wonder what happened to the aerodynamics
The only pic I could find was this.Back to the light-bar effecting range. From pics I see it is put at the very top of the truck at the angle point, so if its implemented into the angle without protruding it should not affect air flow. So depends on how much it's protruding in that angle point. I guess more will be revealed and we will be speculating at this point.
This is the same exact - to the letter - discussion that came out with the Tesla Model 3 5 years ago.
Same forum - same discussion - same. same. same.
I could Easily show 900+ wh/mile in 20 miles launching my Plaid for 15 minutes. The fact that anyone is buying this crap let alone spreading it boggles the mind. Many seem pretty worried about the CT and the momentum it’s going to pick up. Sad that so many have dedicated their time and effort into such a mindless FUD parade.Looks like you might need two range extenders lol….
What ... what does this mean?Pumper'n'dumper
Oh no.The only pic I could find was this.
So yeah, that extra rectangular brick on top of the windshield will do aerodynamics no favors.
Really?
Then you should be easily able to site it ... go for it ... do tells us where Tesla promised anyone 500+ mile range for Model 3.
Yeah, right.
Pumper'n'dumper flies off the handle ...
This video does a good job explaining the situation with EPA calculations.EPA should probably be spot checking these to see if they actually meet the manufacturer’s claims.
They do.EPA should probably be spot checking these to see if they actually meet the manufacturer’s claims.
I see @Evee downvoted the video. Why is it wrong? Can you provide a better source?This video does a good job explaining the situation with EPA calculations.
It does have one set of rules. It defines very exactly how the tests are performed. However, that set of rules also contains some variation in how the test results are translated into the final published numbers.EPA should have one set of rules that all manufacturers abide by. But they don’t.
My mistake.It does have one set of rules. It defines very exactly how the tests are performed. However, that set of rules also contains some variation in how the test results are translated into the final published numbers.
The problem is that there are two major items which matter:My mistake.
Replace “one set of rules” with “one testing method”.
Good video.This video does a good job explaining the situation with EPA calculations.
Some questionable details. Driving 90 with oven heat all which the rear bed cover open can hamper full capability which they seem to admit.
152 miles per full charge? Yikes.
