jonnytdk
Some better pics of the Volk Te37 SL I have.
19x9.5 +22 265/35/19
View attachment 610754 View attachment 610755 View attachment 610756 View attachment 610757
Jesus list mods!! That is sexy afSome better pics of the Volk Te37 SL I have.
Volk TE37 SL drilled for 14mm studs with hub adapter 19x9.5 +22Jesus list mods!! That is sexy af
Federal Evoluzion f60 tires 265/35/19 (these are actually 269 width)
KW V3 Coilovers- Car has a 1 finger gap
Eibach front and rear sway bars
Vorsteiner Copy aero kit
Schroth Quickfit Pro harness
Ceramic coat and tint
Chrome Delete
No Fender work and no rubbing issues (which is surprising given the offset and wide tires)
The hub ring came with the wheels which I got from a member here, no idea what brand or where its from.A+ sir!
where did you source the hub ring?
I've always changed diameters and tires so I can't relate exactly, but in principle, if all size/tires are the same, a lighter weight wheel allows the damper to work more efficiently which equals a better ride and more mechanical grip.For those of you that have changed wheels do you notice any difference in the performance?
Has anyone here installed 8" wide wheels (0.5" narrower than stock)?
Another aspect of this is that open design results in slight loss of range (but better brake cooling) and reduction in weight results in slightly faster 0-60 times, in most cases the acceleration change won't be perceptible and the range loss won't be significantI've always changed diameters and tires so I can't relate exactly, but in principle, if all size/tires are the same, a lighter weight wheel allows the damper to work more efficiently which equals a better ride and more mechanical grip.For those of you that have changed wheels do you notice any difference in the performance?
Might want to also check https://www.willtheyfit.com/No issue if you have a particular wheel you want that only comes that way. Use the fitment calculators @ Fitment Industries to get a visual of the difference to be expected compared to a reference.Has anyone here installed 8" wide wheels (0.5" narrower than stock)?
Chrome Delete
Anyone know if same spec wheels will have different fender flushnesh between LR AWD and Performance? Is there a difference on how far out the wheel hub sits from the center of the car? TIA.
Probably somebody, but most of us are going the other direction!Has anyone here installed 8" wide wheels (0.5" narrower than stock)?
What’s the ideal offset for a 10” for a 275?
Thanks... So that means that a 19x9.5 +35 offset will sit more flush on a LR AWD compared to Performance? Trying to decide on wheels offset to get... LOLFrom what I've gathered on here. Performance Model hubs (P-HUB? lol) allows ~5mm of extra space than SR/LR models.
That is correct, the rotor hats are a little thicker on the non-P so the wheels will sit closer to the fender!Thanks... So that means that a 19x9.5 +35 offset will sit more flush on a LR AWD compared to Performance? Trying to decide on wheels offset to get... LOL
