All Things Direct-To-Mobile
Omnispace's report to the FCC: ECFS
I would think it would take all of about 10 minutes to turn on the SpaceX stuff and measure its influence on the claimed frequencies from the ground. The Omnispace satellite was 17,000 km away, so any emissions should be easily detected on the ground. The frequencies used are for satellite-to-ground communication, so there's no issue with them being affected by atmosphere.
What am I missing?
What am I missing?
Yeah, I dunno..., all they really seemed to have done is say "yes we could detect radio signals". but not necessarily prove it was harmful.
They're saying that those radio signals are introducing noise to their system. As I understand it, SpaceX isn't supposed to intrude into those frequencies at all. Omniverse's assertion is that this much interference was produced by one or two Starlink satellites, and they project that hundreds of such satellites would make their service untenable. The connection to Starlink satellites is a result of timing; the interference was seen during Starlink's short period of DTC testing. They also excluded surface noise from T-mobile because Omniverse's satellite didn't have line of sight to those transmitters.
Reactions: scaesare
What am I missing?
They did measure on the ground simultaneously with the satellite.
Reactions: scaesare
Hmmm... if the FCC grants permission to use those frequencies, how can they not "intrude" at all, unless what that means is that it's not "harmful interference", which is what the FCC often stipulates.
As an example, many things are allowed to use the 2.4Ghz band (Wifi, wireless mics, wireless cameras, etc...) but their modulation schemed, sub-channel selection, etc... must not interfere with other stuff also using that band.
Simply detecting usage in the band the FCC allowed would seem different than it being demonstrated as "harmful".
Omniverse describes the harm in the document. A certain amount of noise is introduced to their signals now, and they expect much more as Starlink increases the number of DTC satellites.
Well, they seem to describe a rise in the "noise floor":
The observations showed that when the spectrum analyzer in Brewster confirmed that SpaceX test satellites were transmitting a 5-megahertz carrier in the 1990-1995 MHz band, the spectrum analyzer in Dubai showed that the Omni-F2 satellite detected a noise rise of 2 to 5 dB across the 1990-1995 MHz band. When the spectrum analyzer in Brewster showed the 5-megahertz SpaceX test satellite transmissions had ended, the noise rise observed by Omni-F2 over Asia and recorded in Dubai also stopped, and the noise floor returned to normal levels.
That's entirely to be expected. As if you are transmitting in that band, then to anybody else, that's "noise". In the same way that multiple devices in the 2.4Ghz band see "noise" from other devices, but your WiFi access point and RF TV remote are able to work at the same time.
But I don't see where they describe the actual "harmful" interference... but rather they talk about:
...interference threat SpaceX’s experimental tests pose to primary 2 GHz MSS operations...
So it seems to me this is largely "we can see them using the 1990-1995 MHz band". That's kind of to be expected, as the FCC granted them permission to experimentally use that band... ostensibly to determine if things like filtering, modulation schemes, etc.. could allow two parties to do so simultaneously.
I was assuming that use of that band was not authorized. If the FCC authorized it, then I too have no idea what Omniverse is going on about.
That seems what they are saying:
In tests of its proposed supplemental coverage from space service at 1990-1995 MHz, experimental authorization holder Space Exploration Holdings, LLC (SpaceX) is causing harmful interference to the primary, Mobile Satellite Service (MSS) operations of Omnispace, LLC (Omnispace).
They refer to the experimental authorization a few times in the doc.
Reactions: JB47394
I took "experimental authorization" as a reference to the Starlink DTC test itself, but that wording seems a bit ostentatious for such a simple thing. Then again, it's a legal document. Dunno. I guess we'll eventually find out.
In the slide deck at th end, they do refer to the DTC test, but specify it includes using that 1990-1995Mhz band:
Reactions: JB47394
Great!
Won't work with the Tesla app though, so unless Tesla implement a service-by-sms option, it won't help get a tyre fixed/car tow outside cell coverage. Although at least you can now text a friend for help. Preferably a friend with the Tesla app...
Even Starlink's upcoming DTC satellite service will initially be text only, but limited data eventually. I wonder if service requests via the Tesla app will be one of the first "limited data" options enabled!
And an important question: Can it receive a text via satellite? Important to know if help is coming.
Non-emergency roadside is already one of Apple’s satellite based off-grid services.
Why wouldn’t it?
If you’re Apple, you’re going to go to the 9’s to make it as close to a ‘regular’ texting experience on grid. And given that the existing emergency satellite texting feature is already two way, it doesn’t make sense that this expanded texting would be one way anyway.
I wasn't aware of that, so I googled it... and... sadly it's only available in the US.
I'm happy for you.
Why wouldn’t it?
I don't recall them saying it would. It might. But to send a text there is a satellite-finding process you have to go through to acquire the satellite first. To receive a text, is there a low-bandwidth wake-up signal the satellite can send you without going through this process? Or can you only receive if you continue to hold the phone in the correct direction for a response? Or how else does that work? Questions. That's why I asked.
Hard to say what Apple’s plans are given how tight lipped they are, but global satellite service takes time to rollout. Look at Starlink. Look at Apple’s emergency satellite service. Look at iridium and globalstar, neither of which actually provide truly global service even decades after they started.
If you're in Australia, given that you already have Apple's emergency texting (and so, there’s no apparent approval/landing rights issues) it's plausible at some point you'll get roadside service too.
…to send a text there is a satellite-finding process you have to go through to acquire the satellite first. To receive a text, is there a low-bandwidth wake-up signal the satellite can send you without going through this process? Or can you only receive if you continue to hold the phone in the correct direction for a response?
Based on the image of the satellite finder in the keynote (and the linked article) and also how the two way emergency texting works currently, it's likely a user needs to keep pointing at a satellite to maintain the two way texting session. (For those who haven't demoed it yet, as one would expect from Apple it's a pretty intuitive and polished interface). I'd guess receiving text messages if you aren't in an active session is a bit like coming out of airplane mode, except instead of turning off airplane mode you point to find a satellite.
Given the signal strengths its had to imagine a truly on-grid/push experience when going through a satellite to a mobile phone, though I'd say that goes for pretty much any sat-to-phone link, not just Apple's.
Reactions: scaesare
I don’t think the Starlink implementation is “point to acquire”, it’s direct to cell via LTE unlike Apple’s setup. So I suspect it will auto roam while still in your pocket, but I don’t have evidence that it will be that seamless.
Reactions: scaesare
