If you have other reasons to justify a new 200 Amp Service then go for it.
But if you do, go to all that trouble your should really take the advice given numerous times to install a Wall Connector !!!
You're going through all that trouble to limit yourself to 32A MAX on a 14-50 outlet.
The ONLY reason 14-50 adapter is supplied with the car is because its a common high amp outlet that might already exist and sometimes available at RV camps.
It makes no sense to install a new 14-50 outlet. Unless you have or plan to charge some other non Tesla EV car or have another need for a 14-50 outlet (e.g. Welder or RV).
If you install a 14-50 outlet, you should, in my opinion buy a 2nd UMC that stays with car ($300) and use a GFCI ($100).
So you save $100 by using a slower performing 14-50. If you use a $500 Wall connector you don't need to buy a 2nd UMC (keep the one you have in the car) and you don't need GFCI. GFCI is not legally required but I'd seriously consider it if you install any outlet for the UMC. Or any outlet in and around where you can have a dripping wet car.
