Answer phone or close roof.
Discussion in 'Model S' started by RYCO, Jul 24, 2017.
Tags:
  1. RYCO
    RYCO Member
    Gilbert AZ
    So, when the weather is nice here in AZ, I have my right side wheel set to do the sunroof. When I want it closed, I push the wheel and no matter what point it is open to, it closes fully. I like that feature.
    When it is open, and my phone rings, I panic. I can't push the wheel to close the roof cause it answers the phone and they can't hear me with the roof open. I can't toggle the wheel to close it that way cause it switches through the options for the phone, answer, end call stuff like that. So I end up trying to fumble through the controls to get to the sunroof controls and by the time it closes, I have missed the call. Is there a way around this? I would like the phone to either pop up on the other side ant be controlled by the left dials or not be controlled by the dials at all or something like that so i can close the roof and answer the phone. Any advice? It's only nice enough to use the roof for a couple months a year here so I wasn't too use it as much as I can. Thanks
  2. R0b_
    R0b_ Member
    Auburn, AL
    Answer phone, tell them to hold on a second. Tap the bottom left corner of the main screen to pull up controls, tap sunroof, tap close.
    If the sunroof is the last section you used, you can skip that tap and just the bottom left corner for controls, then hit close.
  3. Electric1
    Electric1 Member
    NJ/Lehigh Valley PA
    I believe there was a very short lived software release that did both with a single push. Yet another thing they took away from us
  4. Rudr
    Rudr Member
    Issaquah
    Are you able to answer the phone using the center screen? Agree that you have to take your hands off the wheel, but that would still be a quicker and (therefore) safer alternative.
  5. scaesare
    scaesare Well-Known Member
    NoVA
    I have the follow on problem... I answer the phone, realize it's too loud with the sunroof open, and inadvertently hang up the call when I meant to close the roof.
  6. SeminoleFSU
    SeminoleFSU Voluntaryist
    Atlanta, GA
    I usually close then answer to avoid having to put my caller through a wind tunnel which I've heard is very loud. I sometimes miss them but it's an easy call back from the steering wheel
  7. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    You only have to take one hand off the wheel and glance at the center display for a fraction of a second to answer the phone with a single tap. Seems like a reasonable solution.
  8. JohnnyG
    JohnnyG Weee!
    Columbus, OH
    I think you guys are missing his point... He would like to close the sunroof first. When a call comes in (assuming you have your phone Bluetooth linked to your car) it takes over the right scroll wheel and right side of the instrument cluster. He now has no quick way to close the sunroof first (by simply pressing the right scroll wheel). You can't move the sunroof controls to the left side, nor can you move the phone controls to the left side, so when a call comes in, it trumps your sunroof controls with the phone controls. You now have to go through the control settings menu to get to the sunroof settings and close it first. Then you can answer the call.
    All that said, this particular complexity, along with others that I read, have no clear way to answer everyone's needs. Add a function that automatically closes all the windows when you answer a call, and there will be others which would not like that. I think the clear solution is for us to have a macro page, and allow us to create our own one-click macros. You can create as many buttons as you want that each performs a set of commands. That's how you automate and still make it so that everyone is thrilled with it.
    • Like x 6
  9. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    Isn't it nice to have such first world problems?!? I thank goodness that these are the things that I worry about, as opposed to 99.9% of the planet.
  10. Boourns
    Boourns Active Member
    Dallas
    I've hung up in my wife half a dozen times because of exactly this.
  11. Todd Burch
    Todd Burch Electron Pilot
    Smithfield, VA
    Since 2012 I've been requesting a software feature wherein when you receive a call, you can press a single button on the touchscreen that closes the roof and answers the phone simultaneously. (Or delays answering just a few seconds after starting to close the roof). Could also have another button to answer and leave roof open--or perhaps even decide based on vehicle speed.
    Either way, lots of untapped software opportunities that Tesla should be taking advantage of, but aren't.
  12. scaesare
    NoVA
    Or so you SAY....
    • Funny x 3
  13. BonGoHutch
    BonGoHutch Member
    Knox TN
    +1
  14. Zextraterrestrial
    Humboldt/Los Altos
    I have a pano roof but don't own a cell phone (that fixes lots of these so called 1st world problems) ;>
    although I'd really like the option to get rid of the silly phone icon on my dash...guess that is one of those problemy things
  15. Nick B
    Nick B Member
    Montreal
    I hear you, I have a lot of customers calling but most of the time I don't pick up because the sunroof is either open and even then when it is closed the wind noise is just too loud. For important calls I simply call back once I reach my destination. Now regarding friends / family then yes it would be nice to have some kind of option to easily close the sunroof before answering the call.
    P.S. Also be careful when taking private calls, the cars really aren't that well isolated and you can easily hear someone's conversation even when his windows and sunroof are closed.
  16. whitex
    whitex Active Member
    Seattle area, WA
    Sounds like a use-case that Tesla did not completely think through. Their preference to do everything through nested touch screen menus is at least annoying, at most dangerous, especially that the screen can be rather slow in responding, so takes a few seconds to navigate to where you want to go, while your attention is not 100% on the road, and hands not on the wheel (so I guess you're not supposed to do any touch screen actions while on auto-pilot, at least according to Tesla's explicit instructions to keep hands on the wheel at all times while auto-steer is engaged). I wish they'd add a few configurable physical buttons on the dash which could be defined as "turn headlights on/off" or "close sunroof" or "turn off all heated seats" or "set suspension to some level" , etc.
