I used the thinnest gauge wires from Mirrortap MTX-1015. Once I got the wires lined up in the proper spot they went in pretty easy.
Awesome, thanks!
Two follow up questions....
1) Is this (green/black wire) a switched source or you letting your detector auto-shutoff take care of the ON/OFF?
2) Is the 15" kit MXT-1015 ideal or would you go shorter (10") or longer (20") now that you've installed?
Amazon Link: https://a.co/d/8qICOZo
Awesome, thanks!
1. The detector does automatically shutoff with the car
2. I tried the 10in and it was too short. 15in is perfect. The small excess can be pushed back into the mirror housing. It’s very clean looking.
Worked out perfect with the 15” WireTap, my Model 3 BlendMount and my Uniden R7. ✅
Just completed my install… these pics should help others attempting it. 👀
Use a T10 driver to remove the module the white clip (with the green & black wire) is attached to and you’ll be able to manipulate it in a better angle to plug in the WireTaps.
I zip tied the WireTap lead in two spots to secure it, tested multiple times before reinstalling it all. You just need to press the brake pedal to turn the mirror power on to test. No need to actually put it in drive/reverse.
After a drive when the Easy entry cycles or once you put it in park and the driver door closes the power will shut down. Perfect! 😎
Has anyone tried installing with the cheaper options available on amazon? such as Amazon.com
I've seen in videos that the pins need to be really small, but figured it was worth trying it with a sub $15 option before paying $50 for the brand name.
The smallest pin in that bundle work but its very fragile and will bend the pins most likely so take your time. Confirmed on a friends X. It’s a PITA fyi so good luck lol
Don't skimp, everything's better with the WireTap branded kit, quality of the pins and cables.
If not you end up spending more having to buy both kits in the end. $80k+ vehicle is worth the $35 IMO.
Reactions: Lester Green
Wanted to let everyone know that the $12 option worked perfectly!
@Lester Green while I admit it doesn't make sense to skimp on things. All we're talking about in this instance is a wire carrying a small amount of voltage. I think $50 is a ridiculous price to ask for a foot of wire.
You used this one?
What does everyone use for a mount? I have a Valentine 1 gen 2 in my Y currently.
You used this one?
Can't beat Blendmount IMO. Again a premium product, but you get what you pay for. 👍
Awesome adjustability, perfect fit and rock solid mount...no silly suction cups. ✅
You used this one?
I have this mount. Doesn’t break the bank and is rock solid also! I have the gen 1 but this also works for gen 2.
Radar Mount Mirror Mount Bracket for Valentine V1 Radar Detectors - V1 (3001004)
Amazon.com
Or
Radar Mount Mirror Mount + Direct Wire for Valentine V1 Radar Detectors - Gen 1 and Gen 2 (3001204)
Amazon.com
Reactions: bpobill
Amazon.com
Or
Amazon.com
Thanks. I had my gen 1 for like 15+ years. Gen 2 is amazing and worth the price if you decide to upgrade. Way less false alerts and the range is vastly superior. It's also nice doing software updates via your phone.
I have 3 gen 1’s currently and they work perfect. We have no reason to upgrade at the moment. BUT, as soon as one fails…..it will be replaced with gen 2 for sure!
