Autiopilot Still Calibrating after 160 miles
From the manual and a few post I see, most seem to get autopilot activated after about 50 miles. So far, no no cruise control and no autopilot. At delivery , the guy said 50 miles, the onbaord manual says. 25 miles. I called the customer support and he made up a number of 200 miles. Anyone else having this issue.
are you sure it is calibrating or is it simply not enabled? I thought mine was enabled, but it was not (it was added to the order late), so I called customer service and they had to enable it. Sure enough it worked right after that.
Reactions: FlyF4
Yonki
614
1,791
Pacific Grove, CA
In my case I didn't realize AP was turned off when I picked up my Model 3. I drove the 70 miles home hoping I'd get a message like "AP is now calibrated" so I could try it out, but I never got it. The next day I went through my settings and saw that AP was turned off. I turned it on and it worked.
D'OH!
rabar10
Model 3 >> Focus Electric
Moderator
Dec 3, 2010
1,455
190
Indianapolis, IN
I had an issue where during/after delivery the GPS said I was driving across the hills outside San Jose, when I was thousands of miles from that location. Autopilot also did not activate and I assume the two issues were related.
Had to reset the touchscreen (hold both steering wheel buttons down until screen goes black and then you see the Tesla T), and then the map GPS location updated properly and Autopilot was available within 20 miles.
Yes cruise control still doesnt work, and the reverse camera goes black occasionally so wonder if that is causing an issue too, I do have auto steer turned on as well.
Customer service just told me it can be up to 500 miles now. First the manual say 25 miles, delivery says 50 miles , CS 1 said 300 miles, and now CS 2 says 500 miles.
I am in LA so the neural network should have plenty of data in my area over the years right?
The rear camera will go black if you have it open then click on another window then click back to the camera. It's easy to reproduce so they should be able to fix it soon.
It seems like it's trying to open another instance of the camera and it messes up. I mainly see it when I have to camera open then click the charging screen then back to camera.
SDKoala
M3LR RWD / MYLR
Apr 11, 2018
874
982
San Diego
I wrote this in the other thread not seeing this one was getting more traffic:
I had the exact same problem. No autopilot after 100 miles, so I called Tesla and they told me it could take up to 200 miles. After passing that mark, I called again and found out that autopilot wasn't correctly configured on my Model 3. Basically I paid for it, but it didn't get activated.
I finally got on the phone with a rep who stayed escalated a ticket to the right department to get it activated. Later that day, he called back personally to tell me it should be active. Sure enough, the autopilot options where active the next time I started the car.
Bottom line, call back and ask them to double check that your car was configured correctly.
Will do , I’ll try callin again today and getting it escalated , the cruise control worked for about 1/4 mile today by dodger stadium on the 5 freeway going north, then it I got a message sayin disabled. Was hoping it would activate the rest of the trip or on the return leg home and sure enough, not available again
Started seeing this intermittently after the update, is this what people see during the calibration phase?
