Auto Homelink issues?
Discussion in 'Model S: User Interface' started by tliving, Jan 9, 2016.
  1. AWDtsla
    AWDtsla Active Member
    NE
    You don't have to pay. They have a public API. Plugs into other services, no charge. Wink, for example.
  2. msnow
    msnow Active Member
    SoCal
    I was responding to *your* comment:
    "I could be wrong, but wouldn't Tesla have to pay Liftmaster for the rights to incorporate anything involving MyQ? My guess is that if that's the case, it just isn't / wouldn't be worth it to Tesla."
    They wouldn't have to pay Liftmaster to use *anything* that is part of MyQ such as leveraging the open/close signals but I don't know if they would be allowed to query status without permission. Would be great if they allowed it. Might mean more sales for Liftmaster if they did.
  3. Andyw2100
    Andyw2100 Supporting Member
    Ithaca, NY
    The comment you responded to included the quote of the original comment, which involved using MyQ to tell whether or not a garage door was open.
    Obviously any Liftmaster door can be opened and closed using Homelink. The wireless technology to control the door itself is not in any way proprietary. When I wrote "anything involving MyQ" that was obviously referring to the MyQ capabilities over and above the basic abilities of opening and closing a garage door via the standard methods.
    As AWDtsla points out, as it turns out it is a public API, so apparently Tesla would not have to pay, and I was mistaken from the start, but all that is besides the point! :)
  4. ohmman
    ohmman Maximum Plaid Member
    North Bay, CA
    I think Tesla will just wait until they announce the Falcon Wing Garage Door.. it'll probably be announced with the Model 3, along with all of those other things people are speculating. :rolleyes:
  5. AWDtsla
    NE
    Good news. 2.12.126 fixes the bug where auto-close fails to initiate if you've used the homelink button out of sequence. Didn't try to see if they actually fixed the skip button not being a button yet.
  6. msnow
    msnow Active Member
    SoCal
    Nice try but no :wink:
  7. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    Mine still doesn't work consistently after upgrading to .126. Behavior is as hit and miss as before.
  8. RichardL
    RichardL Member
    San Carlos, California
    Mine neither - no discernable difference in behavior
  9. Andyw2100
    Ithaca, NY
    I have no idea what you are trying to say now.
    I acknowledge that my original premise turned out to be wrong from the start, because AWDtsla pointed out a fact that I did not know, which is that the MyQ API is public. So Tesla would have access to it if they wanted it, and it would not cost Tesla anything.
    But my points about our discussion are completely accurate and valid. The discussion was about specific MyQ features, not about the generic open/close features all garage door openers have that MyQ openers obviously have to have as well. They wouldn't be garage door openers without the ability to open and close a garage door. The discussion was about the specific MyQ features that are available in the Liftmaster app, and apparently via a public API that can indicate the state of the garage door.
  10. KEOKE
    KEOKE New Member
    Haleiwa, Hi
    Always opens on approach but only closes on departure 1 in 10 times. I'm ready for bug fix.
  11. Mango
    Mango Member
    Chicago, IL
    Same here. Always opens when arriving but has yet to close when leaving.
    Set it up 3 day ago.
  12. Mango
    Mango Member
    Chicago, IL
    Started working today! IT now opens when arrive home and closes when leaving.
  13. araxara
    araxara S-P85#3,218 X-90D#3,299
    Tucson, AZ
    I’ve had this problem with my Model S since day one. Now I have a Model X and also have the same problem. I’m thinking maybe it has to do with lack of GPS tracking when in the garage. But I’ve also pulled my car out and sat in front of the garage for a while and still have the problem.
  14. preilly44
    preilly44 Member
    Bethesda, MD, United States
    I haven't read all 22 pages of this thread so excuse me if it has been discussed already...but mine often times counts the distance up as I get closer and never opens the garage. For example as I pull in my driveway toward my garage, it will say 30' 40' 50'.
    Anybody else have this happen? It works correctly about 25% of the time. It always seems to close correctly (automatically).
  15. thimel
    thimel Member
    That sounds like it has the wrong GPS location for your garage. Try resetting it after making sure your car's position shows accurately on the map.
  16. tgp1019
    tgp1019 Member
    Chicagoland
    #436 tgp1019, Sep 30, 2016
    Auto close function for garage door works every time now after 8.0 update. Before the recent update it never worked for me, had to close garage door manually. Thanks Tesla update team.
  17. AWDtsla
    NE
    8.0 broke it for me. Sometimes it works. Sometimes it doesn't.
  18. GasKilla
    GasKilla No Gas Know Peace
    Los Angeles, CA
    It should be noted that 8.0 now produces a sound (kind of like the parking chimes) when the homelink signal is transmitted. It took me a few times to understand what the new noise was associated with, but there is now an audible indication (along with the visual indicator) that the signal was sent.
  19. slazhole
    slazhole Member
    Northern VA
    Every time I pull up to my drive from the left side, the garage door opens but immediately stops. I have to click on homelink twice to get it to open all the way. When I pull up from the right side, it opens up on one try. Any idea on what could cause this? I reset the location multiple times and reprogrammed homelink.
  20. msnow
    msnow Active Member
    SoCal
    Mine does the same exact thing but intermittently.
