From @AlanSubie4Life’s charging constant thats 69.3 kWh, so 11% capacity loss from the ”full pack when new” (77.8 kWh) (and also some of the EPA tests).
Reading your posts make me think you have missed quite much of my regular content in the posts?
I very often state that high SOC is not near as bad as the myth. In many cases 80% is tester by research to wear more thN 90-100% (calendar aging wise).
Also doing complete 100-0% cycles (real zero %, not 0% on the screen) has proven to make the Panasonic cells do about 700-750 full cycles. This is equivalent to 700 to 750 times 400 km = about 300.000km or 200K miles. View attachment 970757
So, there is absolutely no need to not go to 90 or 100% if needed.
There is also no danger of leaving the battery at 100% overnight. It will not wear noticably more than it would have at 80%.
I had about 35 full charges om my M3P before I sold it after 2.5 years.
For supercharging, which mainly wear by lithium plating, it might be good to know that low SOC and small cycles at low SOC specially have a healing effect on lithium plating after supercharging. Plated Lithium returns to cycleble lithium and the capaceah I just can't accept the numbers on my S. 30% historical supercharger use. 50% last year.
I just can't except the numbers on my Model. S 30% historical supercharger use 50% last year and almost no change.just can't accept the numbers on my S. 30% historical supercharger use. 50% last year.
The miles don't mesh with your numbers or charts. Didn't I just read a piece about how supercharging isn't that bad? That was recent research however..... I have followed every post you have made since you started the battery talk.
On the 3 I just don't see how one could make my numbers much better for the miles even with your suggestions. Again for the miles and calendar....a futile exercise
My guess is that at ten years you will see the numbers go back to what they are for masses. Efforts won't succeed as much as one thinks. Wish you all the luck however.
Yes money does matter. Whether it's degradation or wear. One has to buy a car at some point. So is the effort(time) to do this exercise if it doesn't fit ones daily needs.
Which is my point. You will not convince large groups of people for mass EV adoption when they're used to looking at a gas tank and it says full and they want it full all the time. They might never use it. Darn it. They will never use it all at once. So one either has to change the batteries or just accept that the batteries are just fine the way they are and use them as we need and let the BMS do the work.
And for the disagreements I keep the disagreements to this thread. I disagree with what you are promoting and the exercise behind it. Some people are being childish and taking it to a personal level on the other threads. Surely we can do better than that as long time members here on the Tesla community forum. I disagree with @AlanSubie4Life. @Rocky_H on this, but appreciate other elements of contributing here.
@msinfo going into people's status updates to give thumbs down. Come on. Surely you can do better than that. Bet you were jealous looking at all the travel I get to go in all those awesome pictures. Like how you down voted the good ones. https://teslamotorsclub.com/tmc/members/outdoors.27441/ enjoy anyone else doing the same.
