Herroweric
Much happier! It was on UPP moderate springs before.Are you happier with the ride and feel with the MPP? What was on previously? It looks good.
Oooooooohhhhhhhhhhhh thumbs up.New wheels
Any rubbing with the front tires? ThanksRunning 21x9.5 square setup with +30mm offset and 265/35-21 tires. Sits flush on the front & rear and don't poke out. If anything, the rear could use a 5mm spacers for a bit more, but it's not needed.
I was wondering the same thing! I'm planning on taking the hub caps off the Gemini wheels and putting on some Nokian's (can't decide on studs or no studs). I live in the mountains so certainly need snow tires. Will get another rim for the summer.Anyone with winter tire setups?
New wheels
Nice! Patiently waiting for the same setupView attachment 722814View attachment 722812
Front - 265/35r22 +32
Rear - 265/35r22 +40
1” gap and flush to the fender - need to lower it next.
Oops there’s a mistake in my specs - the rear is a 285, not 265.Nice! Patiently waiting for the same setup
check this link, very nice thread on wheel sizes.. up to 295.Agree. I’m running stock tire size until they run down a bit more since I still have less than 2K miles. I want an uhp all season to run all year but they don’t make them in the size I want so I will likely swap to F: 265/35/21 R: 275/35/21, if someone makes a 285/35 in all season that would be my preferred choice for the rear.
There is a guy on another thread that is running 265/40, 275/40 but I like the smaller sidewall look
Looks greatGot my new setup mounted on my MYP. 20x10.5 ET35 square with 275/40/20 Continental DWS 06 Plus square. I would have preferred a slightly more aggressive offset, but the combination of Fitment, style, weight, and cost were all factors. This setup saves me 15lbs per corner over the stock MYP set.
Love these wheels. What is the color? Where did you get them? I am looking for the same wheels. Thanks!I’m sure everyone is sick of seeing my car but here they are again. The fronts have a slight poke and the rears are flush.
Volk Racing TE37 Ultra M Spec
20x10 +30 offset
275-40-20
View attachment 664218View attachment 664219
Per requests to OP. 15mm spacers F/R on 10.5 et40. Final et of 25 all around. Pretty wide, definitely will rub and need to run negative camber.
