sorka
Dimming the display isn't going to make any measurable difference.
I agree. Won't making it bright result in more photon pressure to propel you forward
- - - Updated - - -
Lower tire pressure. The traction is in fact limited, the traction control is what keeps the tires from spinning. Pull the stability control fuse if you doubt me- you will promptly get 4 wheel burnouts! Lower tire pressure will gain you more traction (by increasing contact patch) at the expense of rolling resistance. For drag racing, traction is more important than rolling resistance.
BTW, if this were true, then wouldn't putting wider wheels with slicks on give you a much faster 0-30?
