black dot (bad pixel) in headlights (matrix)
Tesla tells me to my surprise that the lights I have on my model y with a black dot in each light is completely normal and does not compromise safety.
I'm quite surprised at my side because its 2 points visible on the photo form a shadowy area on the left side (left lane) and it always catches my eye because I look twice on the small road that there is no one in this location
have you had this problem and if so have
you managed to have them replaced without being told that its completely normal?
I naturally checked on other tesla of the same year as me and all the others do not have this problem
even the lights that tesla photographed and sent to me don't have this problem while ironically he sent them to me to prove to me that its normal ;-) but he talks about the staircase in the middle lol
Thank you all for your help ;-)
It is normal, matrix lights don’t tend to have a full solid beam of light. Is hard to actually show in pictures since the significance varies on how far or close you are from the lights, but take a look at some of the pictures from my MY.
And if you really lower the photo exposure you can start to see the actual pattern of the matrix headlight.
Reactions: Mike_TV
C'est normal, les lumières matricielles n'ont pas tendance à avoir un faisceau de lumière plein et solide. Il est difficile de montrer en images car la signification varie selon la distance ou la proximité des lumières, mais jetez un œil à certaines des images de mon MY.
Et si vous réduisez vraiment l'exposition de la photo, vous pouvez commencer à voir le motif réel du phare matriciel.
Je comprends tout à fait mais je suis à plus de 3m de la porte et plus c'est loin plus c'est visible et le point est large mais très difficile à reproduire avec un appareil photo ;-) Je n'avais pas ce problème au début ;( c'est tout c'est normal que vous voyiez les leds matricielles se fermer car les lentilles ne sont pas supposées pour être à 50cm ;-) mais cela ne résout pas mon problème ;-( ya t'il un diagnostic que l'on puisse faire nous même pour vérifier les leds ? un par un où peut-il le faire au centre de service ? même une vidéo où je montre visiblement la zone d'ombre de près et de loin pour obtenir son aide normale ? ;-)
