Brake pad condition at 25k miles
I got a flat yesterday and took off the tire. I was surprised at the condition of the front brake pad....
well, a lot depends on how "heavy" you are on the pedals, and on how heavy is the car's weight.
For sure 25k mi is on the short side of a brake pad life, but not unheard of.
My M5 is no lightweight and I’m going on 70k miles, I agree that heavy braking would wear them out quicker but that’s not the proper way to stop the vehicle
although my pads benefit from the vehicle slowing down when I downshift. But still 25k is bad
My 1986 Lexus Hybrid had over 80K on it, and had the original pads, and it is only a hybrid. I never use the brakes in my Tesla. I am expecting at least 100K. Unless you are misjudging the regeneration, you never need brakes.
The Dodge Caravan I had the displeasure of owning for 4 years went through front pads every 30,000 km (19,000 miles). Undersized rotors, an aggressive idle speed which caused it to accelerate down hills, and I lived where there are plenty of hills...
@David99 did his brakes for the first time earlier this year I believe... what was the mileage again David?
I feel like autopilot relies on brakes more than my normal driving would. I did replace my front ones at about 70K miles - but I'm also the second owner.
Not sure that autopilot relies on brakes more than your normal driving. It may get closer to a car ahead than you might and then decelerate which feels like brake use but isn't . Generally just regenerative braking.
Interesting. I always just coasted to a stop on my manuals. Always thought downshifting through the gears caused needless wear on transmissions vs cheaper cost of pad replacement
https://www.smartdrivetest.com/how-to-downshift-a-manual-car
Reactions: Electroman
275k miles. I should have done them a little earlier, but 250k is realistic.
My pads had plenty of meat on them at 55k, but I replaced them and the rotors due to the pedal pulsing and generally poor braking performance. Note that brakes should still be serviced (cleaned/lubricated) regularly even if you're not replacing parts. This may be more important on a vehicle that sees a lot less brake use than most. My pads were mostly seized and not much fun to get out of the calipers. I believe my car was from the Chicago area (where I bought it from Tesla) so road salt may have been a contributing factor.
