Tow rating has very little correlation with motor output. Even a weak motor if geared appropriately can do just fine. Wheelbase, tow vehicle weight, rear overhang, tire load rating, brakes and suspension are more relevant.I could see cooling being a huge factor.
The gear ratio in the Tesla Truck is certainly different than the Model 3. And Tesla is not going to give the Model Y a higher max tow weight than it gives the Model X.Four of these rear motors in a Tesla semi will tow 80,000 lbs yet one in a model Y will tow under 5,000?
The range reduction when towing is primarily due to the increased aerodynamic drag produced by what is being towed, not the weight of what is being towed. That’s why you can achieve a lower Wh/mi number with your Bowlus than I can with my significantly lighter Alto trailer; the shape of the Bowlus results in less drag.Range, on the other hand, will be sharply limited at that weight,
@ecarfan This is brings back memories!! Hope I didn't lead you astray and that you have enjoyed your Alto.The range reduction when towing is primarily due to the increased aerodynamic drag produced by what is being towed, not the weight of what is being towed. That’s why you can achieve a lower Wh/mi number with your Bowlus than I can with my significantly lighter Alto trailer; the shape of the Bowlus results in less drag.
Telsa could do that and I don't see why it would matter as they have made people mad before. What the Model Y is pitted against? Is it the BMW X5 which has 6,000 lbs towing?The gear ratio in the Tesla Truck is certainly different than the Model 3. And Tesla is not going to give the Model Y a higher max tow weight than it gives the Model X.
I’m at a campground in Arizona right now, and a few days ago had a neighbor using an X5 to tow his 19ft Airstream, which he said weighed 4,500 lbs. Still hard for me to wrap my head around a trailer that size weighing that much, just because I’m used to my 17ft Alto which weighs — fully loaded — less than 2,300 lbs.Telsa could do that and I don't see why it would matter as they have made people mad before. What the Model Y is pitted against? Is it the BMW X5 which has 6,000 lbs towing?
For the newer folks, here's a little graphic I made that emphasizes what might happen if you pull a "lightweight" but very boxy trailer behind your Model Y.
Indeed, but people buy based on what they think they need 2% of the time, not based on what they need 98% of the time. Ref: entire SUV and truck craze.I best most Model Y owners will be like me. The hitch attachment that came with my Tesla X is in the back of cabinet collecting dust. It is right next to the hitch attachment BMW gave me with my X3.
I do bro.Do you even tow bro?
BMW X5 can tow max 6600 pounds.
Model Y will be able to tow at least 3500 hopefully 5000.
