The same stuff does really apply. It's just that the economic and technical environment of cell phones is different, so the phone makers don't care. (or basically have a desire to have your battery degrade)I know this is off topic, but should I avoid charging my phone to 100% as we do with our Tesla's? I don't know what is myth and what is fact.
Maybe get a very low power charger that would take longer to charge the phone? Maybe then you could leave it plugged in overnight but still not charge all the way. I may experiment with this...So having an e.g. one-hour timer on my phone charger would be better? [than plugging it in and forgetting about it / overnight]
It would still charge to 10)% but then immediately "drive" and the charge would fall.
maybe I could figure out current-percentage to 100% charge-time, and set the timer to give me 90%-ish
battery might be cheap [for me], phone might be traded in after a couple of years [probably not, in my case], but should I be assuming that The Planet is OK with that? or should I be making an effort?
This!Also: what does "100%" really mean anyhow? Its the manufacturer defined limit of when to stop (likely in terms of voltage) charging. Also the percentage remaining is also an algorithm (batteries do not drop voltage linearly so it requires code to produce a guess of remaining capacity).
Furthermore, as pointed out by others the cell chemistry is optimized for the application (capacity, temperature range, material degradation, change speed, etc.) so they roll all this up into a 0..100% "number" that hides all the detail.
You probably already figure that out.....
