TheRealTVGuy
Thank you!No. That only applies to this specific RWD model 3 that has the LFP battery, late 2021 into 2022. No other model 3s.
Yeah, and these EV batteries are so big, that any AC charging is "slow". There's basically no impact on battery life no matter whether you charge at 16A, 32A, or 48A (for the long range/performance models). But there IS an impact on efficiency, because the computers run and consume a constant amount of power (in the hundreds of watts) whenever the car is charging, so it's better to AC charge as quickly as possible.Thank you, sir. So they are the same as we calculate in RC lithium too as we always charge at 1C or below.
Thank you, sir.Yeah, and these EV batteries are so big, that any AC charging is "slow". There's basically no impact on battery life no matter whether you charge at 16A, 32A, or 48A (for the long range/performance models). But there IS an impact on efficiency, because the computers run and consume a constant amount of power (in the hundreds of watts) whenever the car is charging, so it's better to AC charge as quickly as possible.
As for charging to 100%, it's actually better for the battery to not do it all the time, but the BMS needs to see 100% frequently because there's not too much of a voltage difference across SoC levels. As long as you charge it to 100% every 1-3 weeks it's probably fine. You just don't want the thing to get way off target.
Pretty much so yes, I have no level 2 charging in my condo, limited to 120Vso you charge your to 100% every time?
You CAN charge to 100% every time, but it isn't recommended by Tesla, UNLESS you have an LFP battery, which you do not.I’m hoping someone can help a new-ish Model 3 owner. I purchased a used 2018 Model 3 “Mid Range” (single motor) a few months ago.
Should I charge to 100% every time?
At least once per week.The message very confused me as "We recommend keeping your charge limit at 100% and charging fully once per week".
From my understanding "We recommend keeping your charge limit at 100%" meaning the every charge should at 100%.
But why they added "and charging fully once per week". Now it meaning that only charge to 100% once per week.
So which would be better for the battery. I normally charge 3 times per week. First, charge at 90% 2 times per week and at 100% 1 time per week. Or Second, charge at 100% 3 times per week.
Thank you,
With the LFP battery there is no harm in charging to 100% everyday. The Tesla recommendation is to charge to 100% at least once a week.What I have read was LFP. Likesfull charge once a wk - estimated 260 miles range
Charging a LFP battery to 100% all the time still increases degradation although not as much as it does on a NCA battery. But not charging to 100% regularly can cause the BMS to lose track of where the top and bottom are because of the very narrow voltage vs SoC curve in the center. If I had a LFP battery though, I still wouldn't really worry unless I planned to go below 20-30%, in which case I'd charge to 100% immediately before doing that. I'd probably also charge to 100% every 2-4 weeks instead of every 3-4 months.With the LFP battery there is no harm in charging to 100% everyday. The Tesla recommendation is to charge to 100% at least once a week.
Charging to 100% all the time versus charging to 70% most of the time and 100% approximately once per week probably does make a small difference in degradation of LFP batteries, but many drivers may not consider the difference to be worth the bother, since LFP batteries appear to degrade to a much lesser extent than NCA batteries.With the LFP battery there is no harm in charging to 100% everyday. The Tesla recommendation is to charge to 100% at least once a week.
But, butt... this true only for single motor M3's, true? Not dual motor M3's?
Source? This seems to contradict your statement:The same amount of "harm" is done to an LFP pack charged to 100% as any other pack.
“Battery Charging Behavior: Tesla Recommends Charging LFP Models To 100%; The Key Is Voltage. Thanks to the low voltage at which they work as compared to other ternary chemistries, LFP batteries offer better behavior during recharging, significantly increasing the life cycle.”
Unfortunate, there is likely no authoritative source.
LFP batteries were put in US Model 3 for some late 2021 model year SR+ (most 2021 SR+ had NCA batteries) and all 2022 RWD.But, butt... this true only for single motor M3's, true? Not dual motor M3's?
