I initially thought that people might be messing with the door (hitting/twisting) while it is open and charging, but then I figured Sentry would probably catch any culprits
For the people that apply force to close the door (and not let it close automatically), where do you apply force to engage the closure? Do you press on the hinge/arm/fulcrum, or the tip/edge of the door exerting the most stress? I wonder how many cycles and at what stress it's designed to withstand.
It wasn't covered under warranty and mobile service replace entire unit in 15 min. Cost $250@SPACE_EX hasn’t posted back.….if the service tech said anything. Are they seeing this recently, often etc…. I wonder If there’s some manufacturing defect? I haven‘t searched but I haven’t seen anyone else complain about the doors breaking like that on any of the forums since I’ve been on from 2018. I don’t think superglue will be secure enough If it broke in the first place. I would tape the port and the opening to where the arm swings out...to keep rain out.
Could be a manufacturing defect with a certain batch of parts. For some reason, they were manufactured with stress fractures and it takes a lot less force and just a little bit of time before the doors fall off.I had a charge port door fail and had to manually open close it a bunch before service was able to replace it. It would definitely take some force to break it there.
I never apply force to close the charge port door. I always close it from the app, from the center display, or I just wait until it closes on its own. However the door did slam down on the connector a few times because of Tesla's stupid firmware bug that they took a month and a half to fix (charge port door delay after removing the connector was set to almost 0 seconds).I initially thought that people might be messing with the door (hitting/twisting) while it is open and charging, but then I figured Sentry would probably catch any culprits
When that happens, if you just wait a moment, the door will reopen on its own. Not too helpful now, I realize.I just had this happen. I was trying to use a Volta charger that I guess was not functioning. So I tried pulling the cable in and out a couple times just to make sure I just didn't have the connection seated improperly. The cover came down onto the adapter so I slightly pulled up on it to open and it just snapped off. I just made a mobile appointment for Tuesday so let's see how this goes.
Yeah when you look at the cover it seems like only the cheap 3D printed like plastic that goes around the metal pole that actuates is not supported by anything. Since the plastic goes around the metal pole the part that connects it to the cover is hollow. So it's easy to see how it can snap so easy. I've only had my car for 11 months and have only tried to move it up gently a handful of times. This shouldn't be an issue at all.There must be some kind of defect. I have manually opened mine quite a few times and it doesn't break off.
This charge port design has been pretty much the same since 2017. If there was a design issue, we would see all kinds of complaints here on TMC. I haven't seen anything like this until very recently. Looks like a bad batch to me.Yeah when you look at the cover it seems like only the cheap 3D printed like plastic that goes around the metal pole that actuates is not supported by anything. Since the plastic goes around the metal pole the part that connects it to the cover is hollow. So it's easy to see how it can snap so easy. I've only had my car for 11 months and have only tried to move it up gently a handful of times. This shouldn't be an issue at all.
Weird mine was quoted at being $214 here in Illinois. I had a tech come and replace it today and supposedly there is a recall on them so it should be fixed for free. The quote is just for Tesla's record or incase it wasn't covered under warranty.And it happened to me today. Tapped it with my forearm as I slightly turned my torso to look at something. Popped right off. Oddly thin piece of plastic holds it all together. Estimate from Tesla mobile repair $268.
Mine was delivered 9/2021 but was part of the weird 2021 LFP battery version that came out in September.Has everyone who has had this issue had their vehicle delivered on or around 12/2021? Mine was delivered 3/2021 so hopefully it doesn't have a defective door.
Mine was delivered 12/2021. Would be interesting to see if this was a common issue w this build dateHas everyone who has had this issue had their vehicle delivered on or around 12/2021? Mine was delivered 3/2021 so hopefully it doesn't have a defective door.
Yes it's fine. You can cover it if you'd like. They'll replace the whole unit.This just happened to me, same as the pics in post #1. The soonest appointment is late next week, I hope it's ok to drive it in the rain like this!
Happened to me today while I was washing the car by hand. So weird I charged it this morning with no issue. It was like it was hanging on by a thread. BummerCharged this morning and door closed fine. I was wiping down the car and when I wiped over the cap, instead of opening, it just fell off.
Has anyone had their cap break off? Looks like it would have required force, but honestly there was none and hasn't had any that I know of.
Delivered 12/2021.
Not seeing any other threads in this issue.. Soonest Tesla service appt is DTLA in a week.
