Charger solution on private car parking space
Discussion in 'Hong Kong' started by ekwng, Mar 16, 2014.
Tags:
  1. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    So long as you are not using any 'common areas' of the property, you shouldn't need management approval.
    If you need to run cables through a common area, or access a common meter, then you will most likely need approval.
    I suggest you contact a couple of Tesla's recommended electricians (or your own if you have a preferred one). Keep it simple, and you'll keep costs down. 40A single phase (50A breaker), or 32A single phase (40A breaker) should be relatively easy and cheap to get done, and either would be fine for overnight charging.
  2. Hinson Lai
    Hinson Lai Member
    Hong Kong
    Great! Thanks for your help.
  3. icemankaka
    icemankaka Member
    Hong Kong
    got delivered the car i share with my dad (he's the primary user, reverse commuting to NT from HKI for work; and me using at off hours. mom has an ICE and she refuse to go electron.) We hadnt inquired about installing at home since he has sufficient control of the parking area at work and to install the 32/40A charger there (i havent seen the charger in real yet since installation). We liked the car so much since delivery 2 weeks ago and have started asking our building out of curiosity (or in case if mom decides to switch too, but perhaps that wont happen since a few of the carparks we go frequently wont fit a MS).
    Henderson lets us install it on a first come first serve basis based on power capacity (i didnt exactly ask how much is remaining here) but all i know is they charge 3000$ deposit and a $10-20k installation charge.
    so, good to hear here :p
  4. lx3h
    lx3h Charged.hk's Director of Education
    Hong Kong SAR China
    If you want to know which car park fits a MS, you can look it up here on my Best Tesla Model S-friendly Car Park Map: http://goo.gl/rClkgh. If it is not listed on the map, feel free to contribute so others can benefit from your experience.
  5. icemankaka
    icemankaka Member
    Hong Kong
    read thru it, its an amazing list :) but yea, regal HK, that's the one!
    i think you don't have Man Yee Bldg / The Centre (both = Central) too? Let me check it out one day =P i think its just the normal tight bends which is easier if i use both lanes. very high suspension and i shall be fine.
  6. AppleFan
    AppleFan Member
    Hong Kong
    I haven't been to either of those car parks in the Model S but have done so previously in my BMW 3 series.
    Man Yee is VERY tight at the entrance. I wouldn't try it in my Model S. The Center is great - very wide at the entrance/exit as well as the parking spaces.
    The reason though that I haven't been to either in the Model S is that if you go further down to Bonham Strand, there's some street parking there. I have parked there numerous times on weekend evenings and I have not been ticketed once. Park at your own risk!
    Good luck!
  7. Editot
    Editot Member
    Hong Kong
    Caribbean Coast, Tung Chung (MTR Mgt) writes:
    As the installation works for the EV charging facilities plug involves
    different Ordinances and insurance issues, we would not consider to
    provide the installation at the moment.
    Thanks guys ... very enthusiastic.
    Help!!!
  8. Chargers4Bel-Air
    Hong Kong
    Sad and sorry to hear that.
    Many other estates, large and small, including Residence Bel-Air have provided for at least some EV charger installations. The management of those estates have managed to successfully deal with various ordinances and insurance requirements. Thus, Caribbean Coast management's current stance not to consider providing for EV charging facilities is rather weak. If other estates can provide it why can't they?
    >>> Perhaps we should start a list of HK estates that have kindly provided for EV charger facilities. Similar to Locky's ongoing "Best Car Park List", it can help to promote the "progressive" estates and their "green" and EV-friendly management offices' attitude. That may then encourage more estates to follow.
  9. icemankaka
    icemankaka Member
    Hong Kong
    agree its tight but they are very good at regulating traffic. go slow and use all the space and im sure its gonna be fine. we go to a restaurant just opposite from the bldg so unlikely we'd park elsewhere (maybe ifc when the ladies want shopping). have seen some nice low cars there anyways so i doubt undercarriage clearance would be a problem. and i think they have a charging spot up too (owuldnt go down unnecessarily to charge up nonetheless!)
  10. lx3h
    Hong Kong SAR China
    Thanks for your suggestions, if it is blacklist material for obvious reasons, then there is no need to actually try the car park before suggesting. That being said, let's keep to the title of this thread. There are two other threads related to my Car Park Map and you have already commented on them.
    - - - Updated - - -
    Thanks for the suggestions, will add them to my map.
  11. Vmax
    Vmax Member
    Hong Kong
    Some of us, who wants to charge not only Teslas, might have installed a 3rd party wallbox. The dominant supplier for such wallboxes is EV Power in Hong Kong. Did anyone install different brands (e.g. Schneider or others)? If yes, which brands and what is your experience concerning reliability and failure rate?
  12. EBill
    EBill Member
    Hong Kong
    Cableplus makes the boxes for EVPower
    You can also buy direct from them and save a lot of money if you do not need the token reader.
    32A (40 rated) 1P is approximately HK$13k, 32A (40 rated) 3P is approximately HK$16k. Quote from last December.
    http://www.cplus.com.hk/news.php?&lang=1
  13. waidy
    waidy Member
    Los Altos Hills, CA
  14. icemankaka
    icemankaka Member
    Hong Kong
    do they export to Hong Kong and are they rated for local use (without the latter we wont be insured for public liability AND will not be authorized for installation)?
  15. waidy
    waidy Member
    Los Altos Hills, CA
  16. Vmax
    Vmax Member
    Hong Kong
    Looks like they don't offer a 3 phase unit
  17. waidy
    waidy Member
    Los Altos Hills, CA
    That's correct. Most of States do not have 3 phase.
  18. Chargers4Bel-Air
    Hong Kong
    Hi Toma,
    Sorry, I'm probably too late but I got my $10M public liability insurance for my charger at my parking space from Cindy at Prudential ([email protected]). Cost is under $1,000/year. Hope this helps!
  19. nivak
    nivak New Member
    Hong Kong
    LERXT ching, can you recommend me your electrician? Got the quotation from shunhing which in my case is basic installation but still expensive.
  20. Jonathan Tse
    Jonathan Tse Member
    HK
    New here and would like to know how much your management office charges every month after installing your own charger in your private parking space.
