OK, I may have a solution to my "problem".
When I connect to my charger, which is set at 32 amps, I can adjust the charging current in the car to 32 amps.
If I am at a shopping centre, as I was this morning, 16 amps is it.
Is it the case that the current can only be increased above 16 amps if the charger the car is connected to can supply more than 16 amps?
If my car is not connected at home the current cannot be adjusted above 16 amps. As soon as I plug into my charger, 32 amps no problem.
Is this the same for everyone?
