Wow, you guys have gone off the rails.
Let’s go back to specifically what was said and why I corrected it:
So he was dismissing the difference in charging speed from 120V 12A to 120V 16A as so small a number it’s not even worth mentioning, but comparing it to a 10% increase in efficiency from just a voltage change, which he was considering very large. This needed clarification, because it’s extremely overly absolute, conveying a false impression to people that increasing current is meaningless and doesn’t do anything for efficiency, while voltage is the only thing that matters. That’s not correct.
Some of you seem to have gotten all out of the ballpark on this, attacking things I didn’t say.
Yes, of course I am—that’s the point. It only takes one contrary data point to disprove any absolute statement. We wouldn’t really need to be talking about this if we were talking about 10kW or 20kW power levels, because they are all so efficient up there that there isn’t much difference, or if comparing two situations of the same power level, where you're isolating voltage versus current effects. But those weren't this point. When it’s around 1kW, and you’re losing a third of fourth of your power, increases to current or voltage both make a big difference. That’s what this topic was.
You all are ranting and insulting me to point out that voltages makes a bigger difference. Great—I never said it didn’t. I just wanted to make sure people do get the helpful information that at very low power, on 120V circuits, being able to increase the current significantly helps charging speed and efficiency and shouldn’t be dismissed as having negligible effect.
Several people are trying to “disprove” what I was saying with the “at a given power level” paradigm. But that wasn’t the context Yes, that’s obvious that if the power calculates to the same, the increased voltage does have innate efficiency advantages. I am aware of that, and yes, my electrical engineering degree is plenty of “background in electrical science” to know that, @aydyn. The point was NOT “at a given power level”, but if you are stuck using a 120V low power circuit, the current increase increases power and efficiency significantly and shouldn’t be dismissed.
16A might be slightly more efficient than 12A but 240v is ~10% more efficient than 120v.
You're cherry picking your science.
