Thomas Edison
Does anyone think it's worth pulling the front bumper to get the PPF all the way around the edge and also allows you to get around the corner of the fender too?
Here's my install....
Got the film... getting ready to go!
Decided to do the front bumper first.
View attachment 311939 View attachment 311940View attachment 311941
Finished product. Not gonna lie, the picture looks awsome, however there are many cut lines because I couldn't get the fingers/wrinkles out and gave up so I just cut slits to make it fit. From a distance it looks alright but up close you would be like WTF is up with this bumper..... haha
Here's the finished hood. Didn't take before pictures considering it's pretty straight forward.
Tips:
Swipe with even pressure to get the initial water out, then go again with much more pressure to get all the water and bubbles out.
Make sure you keep the PPF wet. If you don't think you will get to a spot in time, make sure you go back and spray it again or else it will dry and tack. Once it does, you will get finger prints or lines from having to peel it back out. Also when you have to pull to peel it, the film stretches. This will cause more trouble, it will shrink back but it takes a bit of time.
Make sure you have a heat gun or at least a blow dryer for the edges. Most of the vids don't show this step, it's important to heat and press down on the edged so they stick well or else they will peel later.
Don't do the front bumper in a full sheet! You have been warned. Buy a pre-cut kit. Your back will thank you and the time savings will be more worth it. It was hard and getting all those wrinkles out was a nightmare. The videos make it look super easy but it was NOT easy.
If your cutting skills might not be good, get a pre-cut full front kit. It's about $500-700 on ebay. Most places charge about $1500+ do do the whole front. The cost savings is worth it if you can tackle the job.
Fusion, what was the dimensions of the sheet you used for the front bumper? I'm considering giving it a try and don't want to spend on excess material. Thanks!
i'm planning on doing a DIY not sure i would go with pre-cut kits or actual rolls any recommendation i'm planning on spending 2-4 hours every weekend for almost 3-4 weekends to wrap the car.
Is eBay the perfect place to get the rolls/kits ordered?
Cool..! Please post the pictures once you are done, i'm inclining towards purchasing the kits too how much did that cost you?I got my precut kit from ServPro. I asked him to leave out some precuts like the emblem and fender cameras.
I’m going to install this weekend I hope depending on how long prep takes!
However my car came with a pen head sized chip on driver fender and I’m waiting Tesla to fix it. It’s infuriating.
I don't think it's worth it. Any edges that are near the panel are hardly noticeable, and from what I see on Youtube that seems to be the norm from professional installers. Having the bumper installed also aid in stretching the film at the right places as the bumper is firmly mounted, and you can use the panels outside of the bumper to keep the film stretched. Good luck!
Anyone here looking to get film in the bay area? The main supplier that I used online is no longer carrying Xpel. I found a place to order a full roll but I don't need that much. It's gonna be at 60" x how many foot you want. I would have to order a 100' full roll.
Has anyone tried doing the entire doors themselves? Seems fairly straight forward - not many curves. I'm having my installer do the full front, but contemplating doing the doors and rockers myself to save some money. Thoughts?
Ok, you've convinced me!Doors are easy. I wouldn't hesitate to do them myself.
Thanks! I actually got a pre-cut kit to make things even easierThe door is fairly straight forward, the tricky part is cutting out the door handle and making it look professional is gonna be tricky. I suggest planning ahead of time on where you want your sheet to go, then cut out the door handle portion before installation. If you want to print out the shape, you can use this file here:
