It's basically a refrigeration unit. Lots of those have a long track record.Hopefully that will continue
As it happens I have grown to dislike solar-thermal; we have solar-thermal for both domestic hot water and also pool heating, and we have a plumber out not infrequently for this or that - not exactly maintenance-free.
If I was doing it again I would have PV dedicated to pool (i.e. exceeding what I am allowed on house that was grid-tied/export-capable), and use the electricity for a heat-pump - negligible maintenance. Domestic hot water more difficult because of higher temperature requirement.
a solar thermal water heater that reduces your energy use by ~95% (Still need backup heat occasionally) for ~$5k...
I just installed a heat pump for hot water
Errmmm ... a single evacuated tubes panel (big enough for domestic hot water for a family - 1.7M x 2M, Peak 1.1kW) here is $500. Some plumbing required, but that's not going to be anything like $4,500
Yup.I HAAATE Solar Thermal. Anyone selling Solar Thermal these days is either ignorant or running a con. Back when PV was $10/w it made some sense. You can get a heat pump water heater for ~$1200 that reduces your energy use by ~70% (the remaining 30% is easily covered by <$500 in PV) OR a solar thermal water heater that reduces your energy use by ~95% (Still need backup heat occasionally) for ~$5k...
Option 1 is less maintenance and you can export the surplus energy. Option 2 is just absurd compared to option 1.
Do you have any use for the system from Sep to June ?No maintenance. Perfect. Total cost was $3000 Canadian installed with electronic automated valve and controller.
No maintenance.
If you get 2cents overnight, just heat the pool at night.No. When it's cold outside, no one wants to swim in the pool.
Solar PV drops to fraction of summer, but even so I will DIY a few kW of panels this year to offset our mid day peak usage as I have a teired rate of 24c peak and 2c /kWh overnight.
Heat pumps aren't terribly effective under about 50F. Overnight may not work well, depending on nighttime lows. I know where I am it goes below 50 regularly in summer nights.If you get 2cents overnight, just heat the pool at night.
That varies a lot by heat pump, and so far as I know by refrigerant. The Japanese have been selling CO2 filled heat pumps for a couple of years now with very impressive COP valuesHeat pumps aren't terribly effective under about 50F.
Don't worry about it. They'll take it as confirmation that god is angry with the liberals.Global warming will depress economic growth in Trump country
Global warming will depress economic growth in Trump country | Dana Nuccitelli
I don't think it stated that climate change would cause issues due to how residents voted. It just suggests that the geographic locales slated to be more directly impacted happen to be "red" states.Huh. I thought global warming started in the 1850's according to experts. Aren't there term limits?
