SageBrush
REJECT Fascism
Then I am happy.Developers and gas utilities have not been pleased with the outcome.
Adding 240v outlets in the Bldg Code is a no brainer. I hope they require a 40 Amp breaker
Make it 50, almost zero added costs.Then I am happy.
Yeah, you could probably spec a certain gauge wire (6? 8?) and then set the breaker size by distance of the run.Make it 50, almost zero added costs.
YepThe climate battle quietly raging this week about US homes
Yet none of the proposals would ban gas appliances. They would only make buildings ready for electric ones, in case future homeowners choose them or future policies require them.
Notice how the EU uses the 1990 baseline and the USA uses 2005 ?EU capitals have been put under pressure to agree to reducing greenhouse gas emissions by 60% by 2030
I assume the 1990 baseline is lower. By how much?Notice how the EU uses the 1990 baseline and the USA uses 2005 ?
There's actually quite a few cities that have banned gas appliances for new construction.The climate battle quietly raging this week about US homes
2005 was ~ peak emissions in the USA* -- about 20% higher than 1990I assume the 1990 baseline is lower. By how much?
Having wired 240V lines in my home and garage I don't understand this. A 240V 50amp breaker is about $10 and 6 gauge wire for a longer run is about $3/ft, probably less for contractors.(I base this number on a 10 year old build where a 240V line was about $200
I'm building a new house. It's at 6400 ft. elevation in the Sierras. No A/C necessary but, of course, we need winter heating. Fortunately, the temperatures in the winter don't get too low. Usually 20 to 30 F at night and above freezing in the day. Rare to get much colder.
I'm installing a heat pump for hydronic heating and hot water. Electric induction range, heat pump clothes dryer.
Wanted to go completely without NG but wife prevailed with logic and we're installing a gas log fireplace as "backup" heat.
I agree. I've installed 240v outlets for car charging. It's cheap. Less than$100 for materials. In new construction with an electrician, add in 15 or 30 minutes for his time.Having wired 240V lines in my home and garage I don't understand this. A 240V 50amp breaker is about $10 and 6 gauge wire for a longer run is about $3/ft, probably less for contractors.
Not an official passivhaus but many of the features. We'll see how it fares this winter. Large windows facing South plus lots of insulation and air tight. (We'll see if we need an air exchange unit)How about passive house?
Heating required would be minimal and could be met with electric sources.
Without a doubt, but please don't belittle the passivHaus standard as a 10% improvement. It is up to a 90% reduction in source energy usage compared to the crappy building codes and work we currently enjoy.I think cheaper renewables have really altered the equation a lot. When solar PV was $5/w it made sense to spend $10k to improve the efficiency of the home another ~10%. Now that panels are <$0.40/w it makes less sense. Instead of spending an additional $5k on triple pane windows you can add ~7kW to your solar array.
In Germany the PassivHaus standard built home is a bit cheaper these days compared to the home built to crappy standard days. It took some years, and as you say, economies of scale to get there. They do without a furnace and expensive ducting which together are big savings. The heating and cooling savings flow entirely to the homeowner.Sure.
But passive definitely needs economies of scale as well. Would love to see how much it would cost if passives were suddenly standard.
