demundus
How can they re-lube both splines from the half shafts in 30 minutes while they charge 2 hours to swap out one driveshaft?
I looked in the service manual and there is no way that it is a 15 minute job to get to the splines out the hub and lubricate them.
What i do see in the manual is that they put greese on the hub, not the splines. Same as what the description of work from mambo says (hub, not splines) Can anyone confirm what they actually are lubricating?
This because I will do it myself and I can make a tutorial (with sound before and after) for anyone here if needed.
Copy from SM:
Think that just lubricating the half shaft between the hub is doable without removing the whole half shaft. Will definitely try it to get rid of that stupid noise.
I'd be interested in this, i asked my shop to get to the splies to regrease and they got nervous when they were unable to seperate the splines away from the mating face (tesla has a special "tool" for it). If theres an easy to understand way to do this, or go to the next step after what you're suggesting
