Cockamamie directions
Several times of late I have entered a destination on my Model 3 screen and been given a crazy route. In this photo I should just make a left and a right, instead it has me going past my turn and winding crazily around a cloverleaf intersection. I now have to run Google Maps on my phone to avoid being led on a wild goose chase. I’ve tried the bug report procedure but that has gone nowhere. Any ideas?
We occasionally see this - even with Google maps.
The image doesn't show enough to fully evaluate what should be the shorter route - taking the right exit before crossing the interstate highway and then entering from the frontage road. It's possible that frontage road may not have an entry ramp for quite a while - and if it has to cross a couple of intersections, the time waiting at stop lights could be why the navigation software chose that strange route.
Google is soon going to release a "feature" to make the default route the "most energy efficient" routing - which may not be the fastest routing. When that happens, I expect we'll see a lot of complaints from Google maps users about odd routings...
At least for now, Tesla is providing what the software believes is the fastest route (even when it seems odd) - though we'll sometimes ignore the routing when we believe there is a better path to take.
Thats because the bug report feature actually DOESNT "go anywhere". It simply puts a pointer in your cars LOCAL logs, so that, if you call for service, you can say "I did a bug report when XXX happened" and they can see it in the log.
This is likely an issue with your local maps and routing. For me, for the past 2 years, the routing has been very good to great. Only a couple of times has what you describe and show happened, in 26k miles and 2+ years of ownership for me.
There is nothing you can do, however, to "fix" this. Bug reports dont go anywhere, and I am not aware of any other function to "update tesla routing algorithms" other than perhaps open street maps.
It's Google's mapping engine and probably Google's routing. I think 1/1000 times I get something this wacky... but I've had much worse routing in VW products where it suggested literally zigzagging through a perfectly gridded city block... and sometimes BMW is wonky as well
My wifes 2019 X3 (which has OTA map updates as well) is consistently worse at mapping than my tesla. We have driven to the same place in both vehicles, and in general, the BMW provides more "quirky" routing suggestions.
Thanks for your replies. Fortunately I was familiar with the area so knew to ignore the crazy route. Since Google Maps on my phone showed the reasonable route, this was not an issue of traffic conditions or database problems. It’s a shame Tesla doesn’t seem interested in collecting these bug reports so as to make their product better. Certainly coming up with just-as-twisted justifications for twisted routes does nothing to help solve the problem.
This itinerary is quite amusing !!!
I got often similar results because it seems that the Navigation try to find the closest freeway
and shows how to reach it, without considering alternate shorter ways to reach your destination
Best would be to have Waypoints, something Elon Musk promised for a long time...
Also it would be great if the Navigation could memorised what itinerary was used when someone don't follow the instructions given.
I think the Navigation was designed to use Superchargers for long trips, and to use majors highways in this case,
but for local trips, the Navigation should try finding the simpler and more efficient itinerary.
Sometime the Navigation selects the shorter itinerary but you may then be using some residential streets with numerous curbs and stop signs
where using a straight avenue or boulevard could be a litter bit longer on the map but faster when driving.
The Tesla NAV routes often won't match the Google Maps routes. Tesla appears to be using stale road data on their server - we had an area with a road that had been added a few years ago. Google Maps would route using that road (it was a shorter/faster route), while Tesla continued to ignore that road for a long time. Eventually Tesla fixed this problem - and now the routes match - for that road.
So part of the problem could be the routing engine rules Tesla is using on their server (and for offline routing in the vehicles) and part of the problem could be stale map data, while Google Maps appears to adapt to new road conditions within a day or two.
Even with the flaws, we're still better off with Tesla current navigation software vs. Tesla's first generation navigation software - which was a bad mix of Tesla-Garmin-Google software and data.
I still use Waze for correct overall routing (on my phone - the Teslawaze option is poorly executed IMO) as it still to me provides the best routing info with real-time traffic updates. It still will go haywire once in a while and try to send me on some wild routes (like taking me off the freeway and immediately putting me back on when there are no impediments on the freeway). But I don't blindly follow it so it doesn't hit me very often.
I am always amused when it sends me on a weird winding surface street route to get around a problem and there are several other cars taking the same weird route. I call that a "Waze Parade."
I often use the Tesla navigation just for the heck of it. And of course, it WILL be used during a long road trip for charging management (even if I use a different stop than it recommends).
Bet you most people don't even know how to look up addresses using the map or those map books.
Because I am "directionally challenged" (lol), back in the day, I used to have thomas brothers guides for like 3 counties in the trunk of my car. Everyplace I might go to, I had the thomas brothers guide map book for.
When I was going someplace I didnt know how to get to, I would bring the TB guide in the house, and write down the directions on a piece of paper. If my wife (who I have been married to for 34 years now) was with me, I would hand her the piece of paper and ask her to let me know when I needed to turn (my first "nav lady").
My wife is the daughter of a truck driver who owned his own rig and drove all over the US, and is absolutely the opposite of me regarding directions. Take her someplace once and she knows how to get there pretty much forever more, and likely can put together a couple shortcuts.
When in car navigation started to be a thing, and I could afford to do so, it became a "must have" for me. I realize I can use my smartphone, but I dont like the "bolt on" look of hanging a phone from the windshield. To each their own on that.
All that to say, I have used in car nav for a while, and at least in my area, the tesla routing is very good. Better than the same model year BMW that my wife drives. Tesla is missing stuff like waypoints (we have sort of beat that to death here), but in general its pretty good, and easy to see on the screen.
My wife is the absolutely worst navigator in the car. She doesn't know how to read a map but then gets annoyed with the car navigation. And most of the time she gets the directions wrong when she does it herself. She wanted to buy a paper atlas to keep in the car and I had to remind her that we have full time maps on the console.
I'm also one that once I've been somewhere I don't need the Nav to get me back again. I mostly use it now because of the battery pre-conditioning when you navigate to a SC.
I
This type of error is something that I've seen, maybe, once in 100 calculated routes. Three weeks ago, while routing to a friends vacation home, the system had me drive past the destination, do a loop, and go to the destination that it had just passed. I saw the error on the map, but followed the route just to try to see why it had chosen that route. No answer - probably just a software glitch.
I
Same thing happened to me many times using google maps most recently a few weeks ago driving from Orange County to a destination in Los Angeles. Had me exit the freeway make a three block loop then get back on the same freeway same direction. Crazy thing I could not really look at the screen as I was focused on the road. The passenger and I had a good laugh about it.
I find the Tesla nav to be much worse than what I was used to with Google (Android Auto). The Tesla nav continues to bug you sometimes for miles, to make a u-turn when you know a different path and take it. Google figured out right away the new path you want to take. And the Tesla nav does prefer highways. Worse, it doesn't have the "Avoid highways" feature that almost every other nav has. I used that almost every time for local trips because our highways are like driving 80 MPH through a landfill: debris everywhere.
Mike
Reactions: JDMerica
FWIW, I used Google Maps and put in the OP's location and a destination on the highway nearby. Depending on where I put the destination, it would sometimes show me the exact same directions as the OP received.
If I move just a pixel or two, it finds the correct route, so it's obviously a Google Maps issue that causes Tesla to route that way. There are some concrete dividers/Jersey barriers which limit lane changes along that route.
